    60
    question bout the e revo
    hello,
    does the brush e revo conversion is it easy to install nd where can i find it online thnxsss
    whats better the mmm 2250 or the tekin rx8 2250 im leaning more to the tekin'
    any more help would be apperciated
    Oct 2011
    DC650, CA
    348
    Try backlogging this forum, or google is my best bet when I needed info help
    60
    k but i tried to find the conversion but counldnt find it:/
    Jul 2010
    England
    5,778
    There isn't a conversion kit, you have to buy the motor and esc ( either together or separately- MambaMonster & 2200kv motor, or the RX8 & whichevee tekin t8 truggy motor ) and install it like you would any other esc and motor ( just a few screws basically ) with a suitable pinion gear.
    Read this thread:
    http://traxxas.com/forums/showthread...-max-questions
    Exactly the same principles. More reading material for the BL newb:
    Erevo 101:
    EREVO FAQ
    Lipo, LVC, Brushless & Battery charger/charging guides & purchasing links:
    TUTORIALS
    Refer to this to find parts, upgrades, batts & chargers etc:
    USEFUL LINKS
    I can assure you though, there are hundreds and hundreds of threads where people ask 'what am bestest BL system?'- you just have to spend some time reading down through the erevo & BL erevo sub-forums- there are pros and cons for the castle and tekin systems, depends what your specific goals are, and maybe your budget too- the erevo faq should help.
    1,333
    As AOD says.. the change from Brushed to Brushless is pretty simple...
    The ESC and Motor from the Brushed Erevo is simply replaced with whatever ESC/Motor combo you choose and the wire from the ESC plugs (ofcourse) to the receiver. And then you probably want a new pinion/spur gear to go a long with the BL motor power...
    For example 19/54 - 21/54 (just examples) depending how fast you wanna go and the voltage you apply
    And then feed the BL motor with Lipo batteries...
    IMO (but that might just be me) If you RX/TX is 27 mhz I would consider upgrading to 2.4 Ghz radio system .
    The feeling/risk of loosing control over the truck is not a nice thought at all. Especially with a Brushless system...
    Slightly Addicted
    60
    thnxsss guys nd i already knew bout lipos nd etc...
    thnxss for telling me bout the e revo
    Oct 2011
    DC650, CA
    348
    good luck!
