Results 1 to 4 of 4
    Jan 2010
    164
    Problem with MMM Fan? Help please
    Hello wise ones
    My ERBEs fan always used to run all the time. Recently it does not. It whirs on startup as it does the battery check and beeping, but then stutters to a stop when the car is ready to go.
    I'm worried if this is a problem or not, and if the car will overheat
    Thanks for any help
    Mar 2007
    ashburn, VA
    569
    I know at least for mine, the fan only runs if needed. if yours used to run all the time then you might have had a problem from the begining. at least if it comes on when you plug in the battery you know the fan works, your ESC may have an issue with the fan activation circuit.
    REVO 3.3, shumacher fusion .21,TC4, ERBE
    SoCal
    114
    Mine spins up on start then stops.
    It only runs when I have been driving it hard.
    kansas
    8,668
    like stated the fan runs during start up & will only come on when the ESC temp is above150 *F... Then when the ESC temp drops below 150 it will shut back off.
