    New Hampton, Iowa
    319
    Racing Rear Suspension
    Alright so through the "woop" section my front end stays planted but my rear end is all over the place? What can i change on the merv to help counteract this? I'm running 70 wt stock springs 1/4 preload in the front and 30 wt stock springs half preload in the back. Any tips about tuning or driving styles would help greatly. Thanks
    http://www.youtube.com/user/dennerracingteamdrt
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,511
    I would start with some heavier oil in the back. I run 80 weight with black springs all around on mine. Start with some heavier oil in the rear and tweak from there.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Feb 2002
    8,549
    run less preload in the rear as well
    TRUMP 16!
    9,244
    Don't forget to adjust for plenty of sag too
    New Hampton, Iowa
    319
    alright thanks guys! and when i refill the diffs, it actually goes inside the big gear right? Like around the 3 little gears inside the actual diff? Thanks
    162
    Quote Originally Posted by latemodelstampede View Post
    Yup inside the differential on those little gears. How much you fill it up also effects how much it tightens up the differential.
    I use 120k in the rear & 50k up front, I drive in very loose stuff. On road is typically the reverse. With a "tighter" front differential compared to the rear.
