Results 1 to 12 of 12
    Canada Ontario
    11
    trx 3.3 PROBLEM!!!!! PLEASSSSSEEEEE HELP!!!!
    i can NOT get my traxxas slayer to idle for more than 5seconds unless i have full throttle down. Any sugestions? please help!
    slayer
    Dec 2006
    Argentina
    4,673
    The spring inside the clutch could be broken, check that... And reset all the needles to factory settings...
    2,215
    Raise your idle speed.
    5,520
    +1 Or you can try riching the lsn, or leaning it, more info on how it runs would help too...
    6
    i think this is due to clutch spring, you should check first this spring then other.
    Jan 2009
    32
    One quick check to see if it is the clutch springs, will it idle if you lift the truck off the ground? If so and your drive train is spinning up, clutch is engaging early on. If not, then you got tuning issues.
    I love his music, I do. I'm a Michael Bolton fan.
    Canada Ontario
    11
    its not the clutch spring, i checked that... and i raised all needles and even lowered but same result, it starts up fine and dies in 3 seconds i have it back to factory settings, no change
    slayer
    Jan 2009
    32
    How much fuel have you ran through this engine? Have you tried a new glow plug?
    Checked the compression? Is it good?
    Colorado
    98
    when it dies, does it start to cut out then climb in rpm first or does it slow in rpm and cut out.
    697
    check glow plug before i sold my slayer it wouldn't idle and then i changed out my glow plug and bamb it idle for five mins
    SLASHING UP WITH MY PEDE
    2,215
    Your engine may be worn out.
    9
    adjust the low end needle in 1/4 turn steps. Do not touch the high end yet. First go 1/4 lean, then 1/2 lean. if there is no improvement go 1/2 turn rich to get back to where you were, then another 1/4 richer , etc. Post results.
