Page 2 of 2 FirstFirst 12
Results 41 to 68 of 68
  1. #41
    South of St Louis
    6,368
    All aluminum, how do you like the center diff? First impressions?
  2. #42
    Dec 2007
    Manassas, Va
    7,127
    that's probably one of the nicest pede truggies i've seen s far. AWESOME build.
    "It's just RC, not rocket appliances"-Ricky
  3. #43
    Nov 2002
    Chicagoland
    699
    ...sorry all aluminum...i thought i put this in his thread..respect.
    Lol....It's all good man, glad you could help him out
    I have yet to try the center diff but I don't have any 2s lying around. I ordered a FLM aluminum center diff housing from rcmonsters but I'm not sure if their inventory is up to date. I can't seem to find it in stock anywhere else.
    I finally ran it a bit in the driveway for 5 minutes to adjust the steering and found that the motor is overheating. I didn't even go past 1/4 throttle since I didn't have the room for it. I know nothing is binding and my mesh isn't tight. I'll have to take it apart tomorrow and see what is causing it.
    XO-1|SlashUE-MMM2200|Rally-SV2&MERV-MMP w/NEU1112
  4. #44
    Hendersonville, TN
    12
    Sorry the content of this post has been removed. Questions regarding non Traxxas vehicles are not allowed on this forum
    Dadx2mj
  5. #45
    Nov 2002
    Chicagoland
    699
    Well it turns out that the overheating issue was my fault. I made the mistake of cutting the motor wires shorter without checking the Internet first. Each strand of the copper winding is coated with lacquer and I didn't clean it up when I soldered it the first time around. I was only running the motor with less than half of the windings being used. My friend was able fix it and solder it properly and was able to run it with great results. The high Kv motor is fast (just like I expected) and runs cool as a 2400/2650 motor. This is definitely a keeper and I am planning on picking another one up for my next project.
    Hint:
    Sent from my iPhone 4S using Tapatalk
  6. #46
    Nov 2002
    Chicagoland
    699
    Another update:
    Had to trim it a bit to fit...
    It fits...
    Multi tasking..
  7. #47
    Wales in the UK
    6,462
    Sweet hardware and good food what more could you need of an evening...peace
  8. #48
    Nov 2002
    Chicagoland
    699
    Thanks man...I had a chance to use the center diff last night. It definitely helped my takeoff using 500k diff fluid (paste )
  9. #49
    5,520
    Nice lot of rc cars! Looks like you had fun!
  10. #50
    Can you explain in more detail what was wrong with your motor. Im not sure what you mean by cutting wires to short, etc.
    Thanks
  11. #51
    Nov 2002
    Chicagoland
    699
    Quote Originally Posted by driver5150 View Post
    Thanks
    NUE motors doesn't come with flexible wires (the newer once now do). The coper wires from the windings go out about an inch past the can. Each tip is pre soldered but I made the mistake of cutting it. Each strand is coated with lacquer so it needs to be scraped or cleaned out and must be soldered together for all wires to conduct.
  12. #52
    3
    mounts
    Hey man truggy looks great....what mounts did you use? It looks like you have the stock ones on there but how did you mount them in the center of the shock tower?
  13. #53
    Alberta Canada
    986
    how is the FLM center diff housing holding up? I've heard lots of negative problems with them.
  14. #54
    Nov 2002
    Chicagoland
    699
    Quote Originally Posted by kslay11 View Post
    I used parts from my spares bin to mount the body....
    I've ran 10 packs on them and they haven't leaked using 500k fluid....so far so good.
  15. #55
    3
    hey man, what hole did you mount your shocks on? I can't let from the pictures.
  16. #56
    Nov 2002
    Chicagoland
    699
    I used the top middle mount for the front and rear..
    For the front, I used the lowest setting and the for the rear I used the 2nd lowest setting..
  17. #57
    RC Champion SLW-SVT's Avatar
    Lake Jackson, TX
    1,638
    I'm using the rpm shock tower spacers on mine. I drilled a hole in the center of the spacer and countersunk it then used one of the jconcepts stampede lowered body mounts and screwed it to the shock tower.
    X-Maxx Max6 | EB48.3 | ET48.3 | Axial Grave Digger
  18. #58
    North of San Francisco
    434
    What shocks are those?
  19. #59
    Lake Jackson, TX
    1,638
    mine are Vorza's his are d8's but they are really the same
  20. #60
    3
    is anyone able to send me the link to these shocks? I want to be sure I'm purchasing the correct shocks. THANK YOU
  21. #61
    Lake Jackson, TX
    1,638
  22. #62
    SLC, Utah
    3,432
    All.... I LOVE your builds... They always look terrific,and with class. U my friend, have very good taste.
  23. #63
    USA
    571
    Quote Originally Posted by all aluminum View Post
    Roller and Vorza shocks:
    Where'd you get those jackstands? That's definitely a good way to work with the truck.
    Your truggy looks awesome btw!
  24. #64
    Jun 2014
    7
    just finished up reading this thread, this is also my first post on this awesome site thats all traxxas based! Very very sic stampede and a n inspiration to build a non "monster truck"!
  25. #65
    Dec 2014
    Pella, Iowa
    37
    I know its a bulldog body but which version of it? There is one for the stampede but I want that little hood scoop thingy. Thanks!
  26. #66
    May 2015
    New Hampshire, U.S.A.
    449
    so wheres the new updates on this?? I was reading then BAM DONE... Hope you pick it up and continue mr. all aluminum...
  27. #67
    Nov 2002
    Chicagoland
    699
  28. #68
    Dec 2016
    58
    Nice setup...good luck with the sale.
