Results 1 to 3 of 3
    59
    Exclamation How Can I Test To See If Lipo Is Damaged?
    hi guys ...
    a 2S lipo, 5300mah.
    how can i test to see if this has been damaged?
    my charger is a thunder ac6.
    newbie, step by step please.
    thanks guys!
    Drammen / Norway
    70
    I don't know that charger, but the most simple way is to just hook it up to the charger, and start a charge. then you do like this guy @ 7.33 min. Press the inc button to gett to the Voltage menu while it's charging
    if one cell is reading way low ore high compared to the other cell , then it's probably done( not sure why you suspect it to be damaged).
    Stian
    12,104
    Seeing that Traxxas does not make a 5300 mah battery, you'll need to contact the manufacturer of the battery to answer your question(s).
