Results 1 to 13 of 13
    Perham,mn
    70
    Pede vxl motor in monster mutt
    Anybody know if my pede motor and esc will work in my daughters monster mutt? Cause I ordered a castle set up
    246
    you will need 48p pinions i recomend traxxas brand ones mot sure about # of teeth probably 18-20 but im not sure
    sl2sh, p4de trail truck
    19,596
    Should be no problem. All MJ models are variations of the Stampede. With the exception of the 1/16 GD, of course.
    Quote Originally Posted by RCTRAIN View Post
    Why?
    Alt-248 on the number pad =
    Perham,mn
    70
    So it's about the same as a 2wd pede
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,511
    Quote Originally Posted by mikeorood View Post
    Yep sure is, the Mutt should already have metal geared tranny the only thing you should need to do is put bearings in place of the bushings in the carriers if you have not done that already. The brushless power will spit out wheel bushings in short order.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    246
    Why?
    this is the p4de section and it uses 32p gears and the p2de uses 48p gears
    19,596
    So the MJ model won't have a pinion already?
    13,835
    It will have 2 from the factory?
    Ya can't polish fertilizer...
    406
    Or you could put a 32P pinion on if you have a 32P spur to mesh with. Its stronger than 48P, but you can't run the gear cover.
    Perham,mn
    70
    So the motor shaft should be the same size
    Okanagan Valley B.C.
    760
    Quote Originally Posted by Dadx2mj View Post
    The Mutt should already have metal geared tranny the only thing you should need to do is put bearings in place of the bushings in the carriers if you have not done that already. The brushless power will spit out wheel bushings in short order.
    +10 to what dad said.
    760
    The same pinions and motor screws, the mount for the esc may be different than the xl5 though.
    RC World
    336
    Esc mount is part # 3626. Pinion and spur you might wanna switch to 48p because then you can run a gear cover. I recommend the rpm gear cover for traxxas 2wd transmissions... Screws that hold the motor to the transmission case are different. Hope this helps!
    Slash VXL, Rally VXL, and Stampede 4x4 VXL.
