Results 1 to 15 of 15
    north east iowa
    149
    would a slayer transmission hold up in a revo?
    With an os .21tm or a picco .26? What would it take to make it hold up?
    Oklahoma City, OK
    2,691
    its the same tranny. Only difference is the ratio....2 gears inside the transmission to compensate for the tire size.
    Pull up the exploded views of both transmissions and get the gear for the revo...I converted my revo to a slayer and used the same transmission, just switched the 2 gears and changed the ratio
    "RED"
    north east iowa
    149
    Instead of changing the gears inside couldn't one just change the spur gear to compensate?
    12,111
    There's a considerable size difference.
    north east iowa
    149
    OK. Thanks. EBay has slayer pro transmissions cheaper than revo transmissions. Plan on ordering one. I'll order a set of wide ratio gears too.
    7,261
    revo 3.3 have 28t/28t drive gear while the slayer have 33t/23t due to smaller tires. using slayer final gears with a 3.3 engine will never get you to wheelie from standing still.
    here are the gear differences, left are my RR metal gears but with the same tooth counts as revo tranny 28t/28t, right are the stock slayer 33t/23t.
    Mar 2009
    1,978
    Quote Originally Posted by ausher1880 View Post
    if you gonna put a slayer tranny in your revo put close ratio and 14/40.... or else you will be burning up clutches due to slip.. not speculating.. been there done that years ago..and you will find that your first gear will strip faster/ easier because it will be staying in first gear allot longer.. and the small primary gear will get hot and disintegrate.. so get the robinson racing primary/ input gear if you going to this conversion...
    north east iowa
    149
    Well then I'll use the close ratio gears out of my 2.5 tranission.
    Mar 2009
    1,978
    unless you put it in there.. the 2.5 stock is standard ratio...
    96
    ok...i had a post called clutch bell heat that after reading this i believe this is my whole problem. My revo is actualy a converted slayer so the heat im experiencing is from the gearing. From what I can see the 5394x foward only kit for the revo would give me the 2 gears i need to fix this problem...does that sound correct?
    north east iowa
    149
    Oh. I thought the 2.5 was close.... well I'll use it for the time being and pick up a close ratio gears too....
    7,261
    i believe the platinum revo come close ratio, correct me if im wrong, i dont own one lol. i only have the platinum body the rest was build from scratch.
    Oklahoma City, OK
    2,691
    @ Scott...yes, if you want stock gears for your Revo
    I have a set of stock Revo gears. if anyone wants them, PM me
    "RED"
    96
    Thanks Red, went down to the LHS, they had one. Im already back together.
    Oklahoma City, OK
    2,691
    RIght on, I'll answer some PMs that popped up while I was waiting for you to chime back in.
    Congrats
    "RED"
