Results 1 to 30 of 30
    10
    Im geting a summit 1/16 for X-mas
    Im geting a summit 1/16 vxl for X-mas. what upgrades do you guys think i should get
    Summit 1/16 vxl
    12,314
    Just upgrade or fix as it breaks.
    The weak points will reveal themselves!!
    10
    well I am also going to get a better charger. what charger do you think is best for me?
    Summit 1/16 vxl
    12,314
    How much do you have to spend?
    Riverton, Utah
    228
    If you are just using nimhs This charger looks good. http://www.rcplanet.com/ProductDetai...ctCode=TRA2932
    very cheap and made by traxxas specifically for their batteries
    MERV, Broken Alias.
    10
    Ya thats good it is in my spending rang thanks, any more stuff I should get?
    Summit 1/16 vxl
    392
    depends what you want, nimh is real old technology, we were using this 20 years ago. Lipo is much better. Plus that charger is going to take at least 45 minutes to charge the battery and probably not very well. I would look for an Icharger, it will charge anything including your real car battery. Lipos are real cheap at ********* too.
    cincinnati oh
    110
    Good advice ibought an ac dc racers edge charger for like 30 bucks i use nimh i have no problems doing back flips
    but i did have a bad esc nothing eles has broke runing in stock config.. hope you enjoy it
    5,520
    I would get a good nimh charger, not a lipo charger, because I know CheetoBoss can't get lipos, ther're too dangerous. PLEASE DON'T TRY TALK HIM INTO LIPOS! HE CAN'T GET THEM!! I would also get some adjustable tie rods, and some aluminum steering knuckles. Hope this helps!
    12,314
    LiPo is no more dangerous than a NiMh.
    5,520
    UGGHH. Lets please not get in to this topic. My mom thinks lipos are EXTREMLY dangerous, and some how CheetoBoss's mom found out. I know lipos are not dangerous, unless you do somthing stupid or wrong to them, but his parents won't have any of it. Please, lets just respect his parent's wishes, and get back to topic about what upgrades he should get.
    12,314
    I respect the parents wishes...
    But posting that LiPo is dangerous without the explanation leads to MORE parents that are misinformed.
    5,520
    Oh, ok. I under stand where you are coming from. Sorry about that.
    12,314
    No hard feelings on my part.
    I wish I had the power to delete all the YouTube videos of improperly used LiPo's doing bad things. Then people such as yourself and Cheeto could feel the power of LiPo. It is like adding a supercharger to your RC!
    But I digress...
    Here is what I did to my MERV and I very rarely walk away broke:
    Steel hollow balls (7028x) to reduce slop
    3M mushroom tape along battery doors to hold the body on
    ^^ You will not be able to do that with a Summit
    Aluminum knuckles to reduce slop and add strength (I have HR but recommend GPM or GH)
    A BB 390 servo due to the stock being known to fry/strip itself
    RPM a arms at all four corners (Front-80692, Rear-80602)
    Center differential (7014) upgrade to help handle the power of
    2200mah 2S 20C LiPo's ran in parallel for ~1 hour run times
    23/50 gearing gets me to ~30mph yet keeps temps in check
    ^^ You will not be able to gear that aggressive due to the tire size of the Summit.
    Shimmed front and rear bulkheads... *LINK*
    Especially do that last part... extremely cheap preventative procedure.
    10
    I really dont know what a lipos is but I like the charger Braden said i should get. http://www.rcplanet.com/ProductDetai...ctCode=TRA2932 any other stuff or upgrades I should get
    Summit 1/16 vxl
    5,520
    Just look at the post Jimmie posted above you!
    Riverton, Utah
    228
    In my opinion about lipos I go both ways. For a 1/16 brushless I say no lipos. You can hit 50 with dual nimhs. If you want to go fast and have longer run times just stock up on a lot of nimhs. Plus they are cheaper and you dont have to buy an expensive charger. I go the other way on larger vehicles. Those big beasts need lipos to perform the best. Most one 1/10 scales can only have one battery so it needs to be lipo. This is just my opinion.
    MERV, Broken Alias.
    392
    Quote Originally Posted by Bradens Traxxas View Post
    not true, lipos are cheap if you get them from the usa warehouse of the place where everyone gets lipos that apparently I can't post here.
    Lipos also can be charged pretty quick if you have a good charger where you can burn up NIMH which aren't anywhere near as robust as nicads.
    still I would go for a better charger as the charger linked probably won't do the best job with the batteries.
    12,314
    I paid less than $7 a pack for my 2200's LiPo's... where can you get stock packs for less than that??
    10
    I don't think I will be using lipo's. It sounds like they are hard to take care of The tires the summit 1/16 vxl comes with should be good for now. The canyon tires are good for off road and on road right?
    Summit 1/16 vxl
    12,314
    They wear pretty fast on road, but are pretty good off road.
    They are hard to beat on the 10th scale Summit, anyway.
    LiPo's are not that difficult to take care of.
    Riverton, Utah
    228
    The tires should be great on the track we are building. I don't think they will wear to fast on it.
    MERV, Broken Alias.
    10
    Ya nice tires
    Summit 1/16 vxl
    Toronto
    414
    Some NIMh peak.chargers are dangerous as well
    These mini packs 1200 stock batt, charging at 2amps will quite often get hot n shorten the life span
    Don't ask how I know...
    When pushing these mini 16th scale the NIMh will get hot on grass without taking cooling breaks
    cincinnati oh
    110
    Quote Originally Posted by CheetoBoss View Post
    Ya the tires are nice. Really, people tell me that lipo's are hard to take care of?
    ,when you go lipo it changes the $ amount you may indure you start to break things. ln stock mod mine has broke
    Nothing i do standing back flips it wheelies so much i lowwered the front r hight it flies and is run like a stadium truck
    2 or 3 foot flying jumps i dont do 10 hih bash jumps
    Run it stock on a good battery charger and learn the trck then see what you would like to upgrade and what needs
    upgraded to handle our upgrade...lol
    Jim
    392
    hard to take care of? pair them with a decent balance charger and you can have them charged in 20-30 minutes versus 45-1 hour with nimh and if they die sooner, who cares at 10-12 bucks a pack. My lipos have puffed before I've ever killed them from charging at too high an amperage.
    Not to mention, rc helis are all flown on lipos and even with monster crashes, they don't blowup and stuff. only time i've seen lipos catch fire is when someone has deliberately shorted the leads to try and sell lipo sacks.
    10
    Thats cool, I didn't know much about lipo's. They sound awesome now thanks
    Summit 1/16 vxl
    Riverton, Utah
    228
    Like Jimmie said I would Upgrade your a-arms to rpm. But probably not until the stock ones break.
    MERV, Broken Alias.
    5,520
    Wow, I had NO idea you could get them that cheap! Lets just pretend my post #11 doesn't exist. I wish 1/10 scale lipos where that cheap...
    392
    They can be had for 20 dollars a pack or so if you go to the right place.
