Results 1 to 11 of 11
Thread: Motor rebuild
    Saskatchewan, Canada
    137
    Motor rebuild
    Hi. I posted this in another section but no answers yet so i was wondering if any of you could help me out..
    I went to rebuild the VXL 380 in my mini but i could not find a way to remove those tiny scres on the endbell. What,is needed to remove them??
    9,244
    a very small screwdriver!
    one of those jeweler screwdriver set
    137
    Isnt it a hex though?
    Slovenia
    320
    Quote Originally Posted by slashbash4x4 View Post
    No, its a TORX size T5
    http://www.ebay.com/itm/Gk3833-New-S...item415e4b256e
    You should get one of those sets it is good to have them handy for cases like that,
    http://www.ebay.com/itm/Torx-Slotted...item5d35367555
    Ontario
    989
    I found one at the local hobby shop and it was a hex I think 1mm to open the motor, nothing really to rebuild though, just clean the inside out a bit and bearings
    137
    Holy next task try and find a 1mm hex
    Jan 2010
    110
    Well, I didn't know they were supposed to be 1MM and I found an English .050 hex driver fit perfectly so I used that when I needed to take a Velineon 380 apart for cleaning.
    Given that 1MM is .039 inches and a .050 driver fit with no effort to put it in the hex, I seriously doubt if they are actually 1MM.
    Why you would find an English sized hex on a metric screw escapes me (interestingly the diff cup screws on a Losi SCTE are metric but also take an English hex driver) but since it worked, I will not complain.
    Ontario
    989
    No I said I think it was 1mm, this was almost a year ago and I sold my tools with my 1/16 slash so you're probably right
    Lol I actually just found my old mini slash on kijiji lastnight and picked it back up after 8 months.. I'll get pics up later
    Slovenia
    320
    It is NOTa hex, read 6 posts above...
    Sure, you can open it with appropriate hex, but eventually you will strip the screw ...
    Jan 2010
    110
    Quote Originally Posted by mtc777 View Post
    Well, I have three different Traxxas 380 VXL motors in my possession and they all have endbell screws that are .050 hex drive. I've got a number of small Torx bits ranging from T5 up that I use for taking apart disk drives so I know what Torx bits are. None of the screws in my 380 VXL motors have the internal lobe structure characteristic of Torx drive (even when looking at them with a 10 power jeweler's magnifier). While two of those motors were used when I acquired them, one is from a new vehicle. So I'd say hex drive is more common than Torx on the VXL 380.
    Maybe someone changed the screws on your motor before you got it? How many Traxxas VXL 380s do you have with Torx drive screws for the endbell?
    Slovenia
    320
    Quote Originally Posted by ta_man View Post
    I have only one Traxxas VXL 380 and I assumed that all are the same, but I guess I was wrong. I bought a new Merv, so chances that someone changed the screws are very flat. I will however check the screws on my motor again when I get home.
