Results 1 to 15 of 15
    Planet Vegeta
    651
    my slash is a rebel
    ok no matter how much i extend my turnbuckles, my slash still steers to the right. the motor loses acceleration and then regains it, the motor also has slow accle. on reverse. how can i fix slop? how do i adjust caster? what should i do?
    RC Champion dgudenau's Avatar
    Michigan
    1,176
    To adjust your camber, I would recommend purchasing a camber gague, like this one from rpm:
    http://www.rpmrcproducts.com/product...auges.htm#Ride
    If your slash still veers to the right after proper adjustment, you might want to check the servo horn. Take the horn off, turn on the car and set trims on your radio to the neutral position, then place the horn back on to insure the wheels are straight. If it still veers, play with the trims on the radio to get the proper setting.
    Anza Slash VXL
    Rustler VXL
    Planet Vegeta
    651
    i checked servo horn already, the chamber is still hard to adjust though
    Planet Vegeta
    651
    motor threw smoke
    582
    Sucks. Only option is new motor now.
    Planet Vegeta
    651
    or a bl motor
    Brooklyn Park, MN
    1,249
    Need the esc too..
    Jun 2010
    Springfield, Ma.
    3,376
    Time for an upgrade! Its always smart to consider an overkill lol, you know, so you never lack in that department again lol. That's how I do it.
    Planet Vegeta
    651
    my dad wanted to get the vxl-3s combo. but he didnt.
    Michigan
    7,740
    Could the skid plate screw plugs have got knocked out of place?just a guess.
    Is your steering bell crank stock,or pro line?
    Planet Vegeta
    651
    stock, wanting to go metal
    Knoxville, TN
    592
    Forget the stock chassis go lcg
    Brooklyn Park, MN
    1,249
    Yeah, cheaper than going stock if you do it with no kit, check out my thread
    http://traxxas.com/forums/showthread...=1#post5297959
    Knoxville, TN
    592
    Or you could two piece it
    Planet Vegeta
    651
    proline's or which one?
