Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 189
  1. #81
    United Kingdom
    756
    I think one of my trenchers either needs balancing or it has gone egg-shaped. Getting some very odd bouce from one A arm!
  2. #82
    USA
    571
    Quote Originally Posted by Pede Pede View Post
    Sweet, should be ordering a set for my slash soon.
    I actually just installed them today. Will post pics as soon as I can.
    Nice dude its looking awesome are you going bashing this weekend???.....peace
    Thanks man! And yes, ran with the 3s. Took a while to finish the battery actually. Close to 35 minutes of runtime total, with a 5 minute break in between.
    Glad I did the upgrades since nothing broke, even after 3 cartwheels!
    Quote Originally Posted by doubletapdaddy View Post
    That's quite a "bonus item". Can't wait to see what breaks. Stripped hex maybe?
    Took the chance to get the bonus item since it was on special on spcracing.
    Fortunately, nothing broke but the hex on the right wheel moved a TINY bit of of place, meaning that it SLIGHTLY started to strip. It was good I was running my talons and not the trenchers.
    Quote Originally Posted by o0wiz0o View Post
    Were you running on 3s when this happened?
  3. #83
    United Kingdom
    756
    I found out it was water ingress. I seal the rims normally but this one was full of water. I have since put holes in all the tires and tuned it upside down and booted it for 10 mins...The amount of water that came out! The rig is a fair bit lighter now.
  4. #84
    USA
    571
    I see. I thought it was caused by the 3s...
    Updates... Sway Bars! (Traxxas part num: 6898) with a little mod done to it. Read on to find out.
    Thanks a lot to forum member doubletapdaddy for this mod!
    Anyways, the sway bars came with solid ball screw connectors (circled in red). I took all the hollow ball pivot connectors from the original shocks that came with my stampede 4x4 vxl (Circled in yellow). I then removed the solid ball screw connector on the sway bars and replaced them with the hollow ball pivot connectors. I did all of this in order for me to pass the original screw that attaches the shock guard (inner hole) on RPM A-arms without any mods at all since the hollow ball pivot connector is the same length as the original spacer that came with the truck.
    Here's a comparison between the solid ball screw connector (circled in red) and hollow ball pivot connector (Circled in yellow):
    Here you can see what I did. Left side is the hollow ball pivot connector (Circled in yellow) VS the solid ball screw connector (circled in red). I did one only one side for comparison:
    Front sways done with hollow ball pivot connector :
    Rear sways done with hollow ball pivot connector:
    Before Sway Bars:
    After Sway Bars:
    Quick recap on "Blue Bayou's" mods:
    -->Blue RPM A-Arms (Fronts) - DONE!
    -->Outerwears Shroud - DONE!
    -->DIY Lid lowering - DONE!
    -->T-Bone racing front bumper and Servo Guard - DONE!
    -->Aluminum Bearing Adapter - DONE!
    -->Kingheadz motor mount - DONE!
    -->Blue Aluminum Bearing Carriers - DONE!
    -->Blue RPM A-Arms (Rear) - DONE!
    -->Blue Aluminum Steering knuckles - DONE!
    -->Blue Aluminum Caster Blocks - DONE!
    -->Rear Teknos - DONE!
    -->Front MIP CVD's - DONE!
    -->ESC Fan - DONE!
    -->Motor fan - DONE!
    -->Aftermarket shocks - DONE!
    -->Better wheels and tires- DONE!
    -->Sway Bars - DONE!
    Upcoming mods:
    -->Wire Mesh over ESC
    -->Aluminum hexes
    Projects:
    -->Plastidipped Talons in Black - DONE!
    -->Chassis Dye, Black - DONE!
  5. #85
    United Kingdom
    756
    Cool....Like to know how they affect handling and with stand bashing? They look like they could pop out?
  6. #86
    USA
    571
    Update! Tekno Rear Aluminum Hexes! I already have MIP alum hexes in front, so I just needed the rears.
    Before Aluminum Hexes (Plastic):
    After Aluminum Hexes (I used Red loctite to help keep the screw in place):
    One more pic (Right side):
    -->ESC Fan - DONE!
    -->Aluminum hexes - DONE!
    Upcoming mods:
    Projects:
    I'll definitely let you know if they are worth it.
    The sway bars (Front and back) are held tightly by the two black screws... I just have to find out when I go bashing later this week.
  7. #87
    SWFL
    217
    Quote Originally Posted by stampede_fanatic View Post
    Remember that they should be secure, not tight. The bars need to pivot with ease.
    Someone stole my signature.
  8. #88
    USA
    571
    Thanks for telling me that man. I thought those bad boys should be on there tight.
  9. #89
    SWFL
    217
    The bars need to pivot so that load can be distributed. On the front, for example, if the left side is compressed (while turning), the sway bar will provide additional resistance in concert with the left shock. When the left and right sides are both compressed (landing after a jump), both sides of the sway bar will move at the same time, providing no additional resistance and leaving the work to the shocks.
  10. #90
    175
    Nice looking truck! We've got quite a similar mod list lol
  11. #91
    74
    Awesome thread. Keep it up.
    How different were the trenchers from the stock tires? I've thought about getting them - a bit more grip would be nice.
  12. #92
    175
    ^ I just bought them Friday, and the stocks are nothing compared to these. I can pull mini wheelies through the snow on the driveway. And also through deep snow at full speed it goes where it never went before! Pretty much the best upgrade so far
  13. #93
    USA
    571
    Cool! Now I know how the dynamics on how the sway bars work on an r/c.
    My car (Daily driver) has sway bars on the front shock towers and rear differential and they are bolted on really tight so my car can take corners faster. This is the reason why I assumed that sway bars on the stampede should be held on tight as well.
    Quote Originally Posted by 4x4stampedevxl View Post
    Thanks! Tough as nails huh?
    Quote Originally Posted by baylorar View Post
    One of the best investments I made man! I should've done this mod first than anything else. My pede handles much much better than stock and on semi-loose gravel, it just turns wherever I point it to. The talons just kept on drifting on semi-loose gravel.
    You will not regret getting Proline Trenchers.
    baylorar, he said it right!
  14. #94
    74
    Nice, good to hear!
  15. #95
    175
    Super tough, and easy/cheap to fix! I'm also looking into bodies for mine, and the raptor is what I want too lol
    Wish they had a 2010 dodge ram body
  16. #96
    USA
    571
    Nice, good to hear!
    Yup! Really worth the investment!
    Hahahha. We have the same taste!
    Ram bodies are nice as well. Too bad proline or jconcepts did not make a body like that for the stampede.
    Update! I want to thank forum member Pede Pede for this one!
    Got this for free at my local hardware store:
    Cut a small piece to make this shape:
    This is how it looks from the side:
    Made sure one side was open to make space for the connector:
    Before:
    After (Wire Mesh Mod over ESC!):
    -->ESC Fan - DONE!
    Upcoming mods:
    -->jconcepts F150 raptor body
    Projects:
    -->Wire Mesh over ESC - DONE!
  17. #97
    SWFL
    217
    What about the other two fans? You getting lazy?
  18. #98
    USA
    571
    Its funny coz I immediately stopped doing the mesh for the other two fans when I realized that I always run my pede with a shroud (*DOH*. Gave a slap on my forehead after... )
    Nevertheless, it was a good mod to do.
  19. #99
    SWFL
    217
    Thats pretty funny. Modding just for the sake of modding. Throw the mesh up on ebay for $18.00. Someone will buy. Actually, just let it bid up from $1.00 - would love to see that!
  20. #100
    6
    I just received my shroud today. The pics in the instructions are not clear on where to put the Velcro on the front and back. The sides are self explanatory. Can you take a couple pics by chance?
    Thanks!!
    L
  21. #101
    USA
    571
    Hahahaha. Someone will bid on it for sure! LOL! I'll just keep this one since it's already on there. Anyways just in case I forget to put my shroud on (I did forget to put it on a few times), I still have the ESC fan protected.
    Quote Originally Posted by Lexlop View Post
    Thanks!!
    L
    You don't have to put velcro on the top front and top rear on the chassis. Just on the sides but all around. Start putting velcro on the front where the gray part of the chassis starts, then follow all the way through the back where the gray chassis ends.
    Just remember, you don't put velcro on top of the chassis, just the sides.
    Last edited by stampede_fanatic; 02-27-2013 at 11:19 PM. Reason: Corrected typos...
  22. #102
    6
    Thanks.
    The reason it didn't fit properly is because I was sent the wrong one.
  23. #103
    USA
    571
    Update!
    Before upgrade:
    After upgrade (Stiffer blue shocks):
    Used this to fill up the shocks:
    -->ESC Fan - DONE!
    -->Stiffer shocks with 50 wt shock oil - DONE!
    Upcoming mods:
    Projects:
    Update... Here's my first painted body!
    Indoor shots:
    Outdoor Shots:
    Grass pic:
    -->ESC Fan - DONE!
    -->jconcepts F150 raptor body - DONE!
    Upcoming mods:
    -->None so far
    Projects:
    I want an avatar... 3000 posts here we go!
  24. #104
    Wales in the UK
    6,462
    Awesome paint job bro looks sweet i bet it will not look like that in a week or two....peace
  25. #105
    USA
    571
    Thanks man! My younger brother actually said the same thing, that's why he told me to take as many pictures as possible while it still looks clean. Lol!
    Update! Guess what it is...
    Top View:
    Front section done:
    Rear section done:
    Finished pic:
    -->ESC Fan - DONE!
    -->Shock Covers (Blue) - DONE!
    Upcoming mods:
    -->Revo slipper clutch upgrade
    -->G-Loc tires for speed runs
    Projects:
  26. #106
    Wales in the UK
    6,462
    Nice bro where did you pick those up too man.......peace
  27. #107
    USA
    571
    Thanks man!
    Got it from here: http://www.badhorsie.com/
  28. #108
    Wales in the UK
    6,462
    Thanks dude thats another thing on my ever growing list of hop ups i want......peace
  29. #109
    SWFL
    217
    These look groovy too. Cut to fit.
    You gotta give it up for the pink argyle.
  30. #110
    Sydney, Australia
    112
    Thanks man!
    Those shock covers look great for $10 but shipping to Australia at $40 is a ripoff. Will look at ebay to see whether I can find some.
  31. #111
    175
    Looks sweet! I definitely need a set of those to keep debris/snow out! Trucks coming along very nicely still!
  32. #112
    USA
    571
    Price is not bad either. It really keeps debris from going in the shocks. Good news for me since there is less cleaning and more bashing! LOL...
    My wife was telling me to get the pink one so that my truck will look unique. Outerwears are not bad either, but they are pricier. Anyways, I just want to stick to the blue theme so I chose blue.
    Quote Originally Posted by Crackelaktor View Post
    Yes, ebay is a good place as well. They are cheaper actually, but they didn't have the color that I wanted so I went to badhorsie.com instead.
    Thanks man! You should get a set as well. Worth the investment in the long run. When I ran my truck on sand without the shock covers, the springs look like it was sand blasted from all the sand that go to the shock. Anyways, I took the shocks out the truck so many times for cleaning afer bashing in dirt, gravel, and sand that it created some loose thread on the A-arms and on one of the shock towers. The shock covers fixed this problem. No more taking shocks in and out! I just use compressed air to clean the dirt off.
  33. #113
    175
    ^ that's what I was thinking too, my stock shock springs are beginning to become chipped. When I upgrade shocks I will get a pair of those for sure!!
    On the other hand time to upgrade the shock towers!! Haha
  34. #114
    USA
    571
    You should definitely get a set. Well worth it man.
    Speaking of shock towers, are you getting the RPM brand or traxxas blue alum?
  35. #115
    74
    Did you replace the shocks completely or just the springs? If so, what springs did you get?
    I have 40wt shock oil, stock shocks (with aluminum caps), but still find my self bottoming out from jumps where the truck is ~4ft in the air. Would like to not bottom out ever hah
  36. #116
    Wales in the UK
    6,462
    Dude upgrade your shock shaft to the hardened ones the fronts are traxxas no.1664t and the backs 2656t so they will not bend and use 50wt oil and you should be able to do higher jumps........peace
  37. #117
    USA
    571
    I replaced the stock shocks with Traxxas Big Bore shocks, installed stiffer springs from hot racing, and changed the shock oil to 50 wt. IMHO, the big bores helped a lot man.
    Less bottoming out since rebound was slower due to the thicker (50 wt) shock oil.
    Listen to this guy too baylorar . He knows his stuff!
  38. #118
    74
    Sweet, thanks for the info guys
  39. #119
    Apr 2013
    16
    Smile Price
    How much did all the upgrades cost you? I'm planning to do all of this to my pede also. Thanks
  40. #120
    USA
    571
    Quote Originally Posted by Mackaylei View Post
    Hi and welcome to the forum!
    This is a good topic to read:
    http://traxxas.com/forums/showthread...nt-on-upgrades
    You will see in that topic how much guys spent on their 4x4 pede's, including me.
