Results 1 to 29 of 29
    12,314
    Parts Compatibility...
    Just reorganized my spare parts... seems I have a few cups (5681) and locker output shafts (5678) but no gears to put in them. I found an inner diff gear set (5382X) but it has parts that are not needed like the I-bar, pin, and the two output shafts... I have lots of those from previous purchases of this set. So I went to eBay to see if anyone had just the little gears for sale... possibly even an upgraded version and ran across this:
    This kit seems to have 4 of the little gears compared to two in 5382X:
    But does anyone know if they are the same size??
    198
    i look to you for answers! i thought u were the smartest one on here! i have nooo clue sorry
    12,314
    Far from it...
    Looking closer at the top pick, the bottom, two gears might be different on the back side even if they are the same size.
    Victoria B.C Canada
    5,437
    Well the stampede kit has the same spiders so it is very possible. if so very good find.
    Sent using lipo power
    Mountains cant stop me
    they have tried
    12,314
    What is the PN on the Pede kit?
    Toronto
    414
    I counted 13 tooth on my lil iPhone screen
    Looks pretty close but pics are not to scale
    No idea besides the 13
    Victoria B.C Canada
    5,437
    6882 same spiders and outputs except
    The outputs are machined down in size at the outer connecters.
    Dollars to donuts those are the same it would make sense and cent's
    they have tried
    12,314
    It seems I am only chewing up spiders when I blow a diff... it would be nice to be able to buy just those.
    Half moon building out back
    730
    Jimmy did a little fast digging and the Stamede, X0-1, and Slash 4x4 all have the same part # 6882X
    Ran down and checked my Pedes output shaft next to a Summit shaft and there seems to be some difference in them in that the Summits is a little bit wider where it inters the case. Other than that they all look to be the same.
    Only Difference between part no. 6882 and part no. 6882X is that 6882X has the carrier support.
    Which you where probably already aware of.
    I have no idea where or for what the "C" clips would be used for that are in the kit you found on E-bay, unless that is something new that has been added.
    Endeavoring to persevere !
    3,459
    Fresh off of Ebay : GPM Hardened steel diff gears. They are designed for the erevo but does fit into the summit differential as well.
    http://www.ebay.com/itm/160973128587...=p5197.c0.m619
    they are very hard to come by (I have been searching the bay for 5 months before these popped up) buy them fast before I am tempted to buy another set.
    EDIT : not so hard to come by, The Toyz are selling them now.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    KC
    310
    Why are you blowing so many spider gears?
    And are you sure about those revo gears fitting in lockable diffs? the output shafts might be different on a Revo than a Summit.
    3,459
    Quote Originally Posted by satyrisci View Post
    under stress the plastic diff cups will stretch/ deform and the diff gears will mis-align just a lil and CRUNCH.
    12,314
    I have only blown one... lol
    KC
    310
    hahaha, I run brushless motors and i have only messed up a diff by over-tightening the slipper clutch nut.
    12,314
    Yeah, I have my slipper adjusted right finally... now I only need a set of spiders to complete a diff.
    730
    Jimmie ya say you need spider gears? I have a couple of extra sets. Will send you a set if you want.
    When I bought the Tekin unit bought 4 differential rebuild kits just in case, but sense I went with the Dewalt doubt they will be needed. My slipper is a little on the lose side due to my trucks weight, just to be safe.
    Victoria B.C Canada
    5,437
    You will need them at some point.
    The dewalt can destroy diffs quite well if given the opportunity
    they have tried
    RC Champion rizz0d's Avatar
    Jan 2002
    1,039
    did we ever figure this out? i need a bunch of spiders (had to rob from the emaxx...a couple times) lol. do the spiders in part no 6982 match the spiders in our summit diffs?
    12,314
    I think the top two do, but from what I see in the pic the bottom two do not. But this has not been confirmed either way.
    jonesdallas
    Guest
    I took a peek into this, don`t think its all 4 the same.
    12,314
    I kinda figured the two that drive the axles are different... they really have to be to engage the shaft.
    Victoria B.C Canada
    5,437
    I wonder if you could drill those out and use them.could call it the 241 spidergear mod
    they have tried
    jonesdallas
    Guest
    Its not drilling you would be concerned with, the ones with the larger holes are the ones that DO NOT fit. If you drilled... all 4 would not fit. However, if you could built up the insides of the big holed gears with JB. maybe that would work.. Just kidding. LoL
    I think were out of luck on the 241 gears.
    Arkansas
    527
    A little off topic but not really.....does anyone make an aluminum diff cup for the Summit? I'm looking at rebuilding my first set and would like to replace them while torn apart.
    12,314
    Yes... a shop in Germany.
    http://www.truckmonster.de/shop/
    Newcastle, Australia
    969
    I think Hot Racing also makes an aluminium diff cup for Summit? Actually that might be E-Revo? Are they the same?
    12,314
    Revo and Summit diff cups are different.
    Arkansas
    527
    Thanks guys! I found an old thread that referred me to a guy on here that was buying like ten at a time from this website above and reselling them from the. I have reached out to both.
    I assume it's only a matter of time until a local shop offers them......ust dont know if I can wait that long. LOL
    Thanks again!!!
    730
    Just ordered a set of these
    https://www.hobbyetc.com/item.cgi?pa...e2Oo8mvPEveKFA
    along with the Toyz when they are back in stock
    http://thetoyz.com/Traxxas/Revo/Gears-Covers/GPM/16710/
    Will keep everyone informed of my thoughts on these products when I get them.
