Results 1 to 11 of 11
    Goshen, KY
    152
    ERBE overheating NIMH batteries.
    I just got a used ERBE and its awesome! After running the Erevo for around 10 minutes doing speed runs on the pavement, I stopped the truck for inspection. The 8.4v 7cell NIMH batteries were so hot, they started to melt the plastic wrap off the batteries. The batteries are name brand and are about 2 months old. The esc is set a factory default with the low voltage turned off since they are not lipo. Any idea why the batteries would do this?
    9,244
    The system is really designed for lipo.batteries. the nimh don't supply enough juice
    Goshen, KY
    152
    Traxxas use to sell the system with NIMH batteries correct?
    The Netherlands
    854
    Stock gearing?
    And NiMHs do get hot, due to the high internal resistance of NiMH cells and the huge currents demanded by the esc.
    Goshen, KY
    152
    I just checked the gearing. Its 18/54. I'm guessing I should change it to 18/65? Will it make that much difference? Thanks guys!
    The Netherlands
    854
    Yep 18/54 is a good gearing for 4S lipo. NiMH i would totally recommend 18/65
    Goshen, KY
    152
    Thanks Guys! I'll change the gearing and see what happens.
    9,244
    Castle does not recommend nimh with the 2200
    I tried mine for 5 minutes went to lipo and never looked back!I have 4 of them sitting around collecting dust
    kansas
    8,668
    Quote Originally Posted by gb77 View Post
    yes going back to stock gearing 18/65 will help with the temps. the MMM will be much happier too..
    it will be even happier with Lipos...
    Goshen, KY
    152
    Thanks 87 GN. Im sure I will be going lipo. Its going to be a few months though. I run lipo in my stampede vxl and its a beast. The MMM is running cool even though the batteries are way too hot.
    Central NJ
    1,245
    The Nimhs just dont cut it. Even easy on the throttle they just dont have the capacity to supply enough current. The 18/65 will make it not as bad but still bad all the same and the truck will seem lame not even making 30mph.
