Results 1 to 3 of 3
    Ashley, MI
    204
    Stock driveshafts rubbing ?
    I was just wondering if its normal for the stock driveshafts to rub and gouge from rubbing on the shocks. Both of the fronts ones are like that. I know the left side is because I broke the lower a-arm and didn't notice it right away because it was a small break but the driveshaft on the front right is worse and it isn't because of a broken a-arm? Help please!!!!
    1,350
    Yeah I think that's pretty much normal. I know mine did anyways.
    BNE
    704
    Is sort of normal. Make sure the screw holding the bottom of the shock does not protrude out the other side of the lower suspension arm as this is usually the main cause of the gouging.
    Always get a 2nd Opinion!
