Newbie - motor positioning for gear mesh
This is a complete newbie question and I don't even know what to search for, so feel free to redirect me to an existing thread that answers the question if there is one.
We have a stock Rustler XL-5. It comes with a 16/90 gear set installed at the factory, and a 28/86 optional gear set in the box.
We wanted to try the 28/86 conversion, but the gear pair is too large to mesh at all. The stock setup includes a plastic bracket (3790 - gear adapter, fixed) which locates the motor in a single "fixed" position. Basically, it fills the slotted motor screw hole on the lower side so that you cannot use the range of the slot.
What is the [B]correct[/B] way to change to a new gear pair? Do we remove the plastic adapter completely? If so, what locks the motor securely in place to maintain the correct gear mesh - is it done only by the clamping force of the two motor mounting screws?
Any tips and advice welcome. Thanks in advance.
