Dusty Motor shroud or other dust protector?
Hi folks!
After steering issues, the biggest problem I have is grit infiltrating the motor through the cooling vents and causing it to seize, and also somehow getting into the pinion/spur gear space and getting lodged in the gear teeth.
Looking hard at the Dusty Motors shroud, would like to know if anybody's used this or a similar product, and what I can reasonably expect? At one point I have wrapped the motor in a section of pantyhose but that was sketchy at best.
Virtually every driving session that isn't on bare pavement ends in a seized motor, and it's starting to rankle.
Thanks!
