First gen XO1 upgrade with TSM ?
Just picked up a first gen XO , without TSM. The car came with the apple dock TQI. Already have the new version TQi with bluetooth module from my XMaxx.
I just want to add TSM to my first gen XO and use my bluetooth TQi for both my Xmaxx and XO.
1 Do i just need to buy the TSM receiver?
2 Can I also lock/unlock the (100mph) ESC with my bluetooth Tqi instead of the one with apple dock?
3 do I need to update the (stock first gen) XO servo as well to get TSM ?
All these TQi versions and receivers are a bit confusing. Thanks!
1: Yes
2: Yes
3: No
You can do everything you could before with the dock as you can the Bluetooth app. With the new receiver you will have to bind it to the transmitter. To do so do the following.
press and hold the transmitter's SET button as you turn it on. Press and hold the receiver's LINK button as you power up your model, then wait for the transmitter's and receiver's status LEDs to turn solid green—which only takes a second or two.
[IMG]https://uploads.tapatalk-cdn.com/20180911/0effd2160a93d692b74d5cd08e949065.jpeg[/IMG]
You can then lock the receiver to the transmitter by going into the app under garage, model memory and tap the padlock so it’s locked. You might have to program the multifunction knob on the transmitter so that it controls the TSM. Please refer to the menu tree in the manual as to how this is done.
If you have any questions or something doesn’t go right, we’re here to help!
[QUOTE=Mmirage;6468920]May I use your XO knowledge again. My car came with the standard bumper, no splitter included. Is it correct that i just need to order part number 6433 to get the complete splitter ? In the parts list various splitter related parts (extensions?) can be found.
Thanks!
Also have pretty hard time removing the receiver box. The box must be lifted to get the antenna of the old non-TSM RX out.
Sorry for all my noob questions.[/QUOTE]
Yes, part #6434 includes the new splitter with the extensions. For removing the receiver, the receiver box can stay where it is. Only the cover needs to come off. There is one screw to remove and the other side has a flange that hooks into the receiver box. The receiver itself is stuck with double sided tape, to remove, slowly and gently pry the bottom of one side with a flat blade screwdriver.
