Results 1 to 4 of 4
Thread: rear posi fluid
    Nov 2003
    puerto rico
    163
    rear posi fluid
    i was thinking to use automotive fan clutch silicon fluid instead of grease to lock the diferential,if it can lock the fan clutch it should do the job,anyone have done this before?
    Jan 2004
    The Coast of MA
    382
    how does a diff 'lock' and whats the point?
    Jan 2002
    warrior run pa
    265
    posi
    you can try automotive grease a heavy kind will lock up the diff to a point or try ofna diff lube you can tune the diff with different weights of oil ..... or jb weld them
    get real . get traxxas !
    Dec 2003
    Polkville,NC
    174
    When you lock your rear end it gives you Positive Traction. Both wheels turn together instead of slip wheel traction. Works great for dragging and crawling, but not good with just every day hard core bashing, too much twisting and turning!
    Fantom .18| Hitec 645 Servo| RPM A-Arms| RPM Shock Towers| RPM Skids| RPM Bulkhead Braces| Proline H2 Body| F350 Washington Redskins Body.
