    Feb 2004
    Ada, Ok
    22
    Unhappy Help with a servo problem
    I am having a problem with my throttle servo. It will be a little difficult to explain, but I will do my best. I plasti-dipped my servos this week, and put them back in tonight. I got everything hooked back up, and my throttle servo was having problems. It is like it is binding up. A first it would only move in very small amounts in either direction. I would pull my trigger to full throttle, and it would barely move. If I take my hand and turn the servo to where it is at full throttle while I am holding the trigger down, it will work. I can pull the trigger, and let off again, and it will work properly with the throttle. Now the problem is that the brake side won't work. I can pull to full throttle and that will work, but the servo won't move the other direction to apply the brake. If I then take the servo and move it to apply the brake with my hand, it will work on that side. I can apply and release the brake properly, but then the throttle side won't work. I checked for binding everywhere in the throttle and brake linkages, and everything looked fine. None of the cables are bent. Then to be sure it wasn't the servo itself, I switched with the shifting servo, and it did the same thing. The steering servo works fine, and the other two servos work fine with the forward/reverse shifting. I did not make any adjustments on the throttle linkages at first. They were exactly the samen as they were before I took out the servos. After I couldn't get it to work I adjusted them a luttle, and nothing changed. Could the plasti-dip have messed up both servos? Any ideas on some problems? If this didn't make sense, or is too confusing let me know. I will try to explain it better. Please help me.
    www.superior-motorsports.com/SMS%20rides/Craigs%20ride/craigs%20ride.htm
    Dec 2003
    Polkville,NC
    174
    Might sound dum but try new batterys or recharge the batterys if you have rechargable. If that dosnt work buy you a Hitech 645 and you will be real Happy!
    Fantom .18| Hitec 645 Servo| RPM A-Arms| RPM Shock Towers| RPM Skids| RPM Bulkhead Braces| Proline H2 Body| F350 Washington Redskins Body.
    Jan 2003
    Oshkosh,Wi.
    626
    Take the servo horn off and see if it works then. When i dipped mine I had problems and had to do some more trimming around the horn area to get it to work properly. It was well worth dipping though.....no more water problems.
    Feb 2004
    Ada, Ok
    22
    I forgot to metion that I had already put new batteries in. If I take the horn off the servo, it works fine.I will try to trim a little off. Maybe the coating is rubbing the bottom of the horn, and not letting it turn.
    Jan 2004
    Bristol, England, UK
    65
    I know this sounds really stupid, but open up your reciever box an make sure ebrythin is in the right place an tightly an also that there are no damaged wires. I installed a hump pack recently and got the battery wire mixed up...almost had a runaway (with a failsafe) but lukely it hit WOT when it was behind my friends T, so it just sent the wheels spinnin an chucked mud all over me while i shut the engine off
    formerly: getinasmaxxsoon
    Dude what you use to run your Emaxx, i use to start my smaxx! (get some nitro!) smaxx: Traxxas big bore shocks, sirio bb pipe, fuel filter, duratrax hump pack, fail safe, RPM full skids, stock shell (with about 5m worth of duck tape on it) :D and 10 zip ties to "support" my front end :p
