Results 1 to 13 of 13
    Banned by Warnings
    Oct 2004
    Tolland, CT
    2,240
    Question Air filter oil substitute?
    I'm over my friends house and I forgot to bring my airfilter oil. I've heard you can cover your airfilter in WD-40 or fuel, but you just have to clean it more often. Is this true? I'd like to go bashing tomorrow, but I don't want to mess anything up. Thanks for your help!
    -emaxxer2002
    Banned by Warnings 72'dolphins's Avatar
    Nov 2004
    Boca Raton, FL
    3,450
    TRAXXAS says use clean motor oil if you don't have AFO.
    Banned by Warnings
    Dec 2004
    New Jersey
    155
    your friend doesnt happen to have a dirtbike does he? if he does use the air filter oil for that its actually alot better
    RC Turnbuckle Jr. ip42800ht's Avatar
    Dec 2004
    San Jose, California
    3,491
    Well, first things first. If you don't have any type of filter "oil", don't run it at all.
    Motor oil will be fine for TEMPORARY use. I'm sure your friend has some motor oil, some place or another.
    Banned by Warnings
    Oct 2004
    Tolland, CT
    2,240
    Is 3 n' 1 oil okay???
    -emaxxer2002
    Nov 2004
    canada
    474
    https://www.amsoil.com/storefront/afo.aspx
    doesn't get much better than this right here. i use the spray can just cause it's more convenient. and i use this on my bearings and hinge pins. it's a little better than wd-40 cause it "creeps" into all the nooks and crannies.
    https://www.amsoil.com/storefront/amh.aspx
    List of mods WAY too long!
    Nov 2004
    Caldwell, ID
    54
    I use K&N AFO from my 1:1. Its like $10 for the kit and it comes with a cleanerand the oil. Plus it lasts forever on the T-maxx.
    Aug 2001
    NYC
    113
    Marvel's Mystery oil.....it's good as both an air filter oil and a after run oil (in fact this is what Traxxas includes for air filter oil, along it's what's in the K&N filter recharge kit, which is also worth the $$$ and is cheaper than most "R?C" filter/after run oils)
    Feb 2003
    Stevens Point, Wisconsin
    1,598
    MMO is what I use for both!!
    Visit WisconsinNitro's Tech tips page.
    Your official & best source for WaterProofing (Plasti-Dipping) your TMaxx.
    http://wisconsinnitro.com
    Banned by Warnings
    Oct 2004
    Tolland, CT
    2,240
    Well I found some 10w-30 motor oil. How much should I put on the air filter???
    -emaxxer2002
    Feb 2003
    1,598
    I've always washed the filter with soap and water.. Sqeeze water out and dryed..
    then I put it in a zip bag and pour a good amount of oil on it.. now work it back and forth, soakin the oil up in the filter..
    Now take a rag or paper towel and soak up the loose oil by squeezing the filter in the rag.
    Banned by Warnings
    Oct 2004
    Tolland, CT
    2,240
    Allright good. I already washed it with warm soa and water. Now I'll do that!!!
    -emaxxer2002
    I need a weapon!
    Jan 2001
    724
    Evilpete,
    The oil that is included with the Revo for the air filter is made specifically for use in the filter. The part # is 5263. If you put Marvel Mystry Oil on the filter it will not have the same filtering qualities as the correct oil. The oil that comes with the truck is slightly sticky and this quality helps to hold the dirt as it goes through the filter. Check the link below for more info.
    BIG L
    http://www.traxxas.com/support/howto....htm#airfilter
    I'm Tired of follow'in my dreams.......... I'm jus
