    Jan 2006
    Omaha, NE
    41
    Belt hitting motor
    I just put my 27 motor in my 4-tec and i noticed the belt ir sitting on the motor and is rubbing on it. Is this bad or not a problem?
    I dont really see how to fix it since i have to sit the motor up that high to reach the gear.
    RC Turnbuckle Jr. razer's Avatar
    Oct 2002
    Streetsboro, Ohio
    15,087
    I wouldn't consider it a problem, but it is adding friction to the drivetrain. I used bigger spur gears so that I could also use bigger pinions & move the motor away from the belt.
    Feb 2003
    Portsmouth, Ohio.
    76
    I've had several motors rub the belt. You could solve the problem by adding a different pinion gear. But that's entirely up to you.
    Current labor of love.
    Traxxas Summit 1/16 VXL
    May 2007
    9
    Sorry to dig up an old thread, but I am having the same problem with the belt hitting the motor. I was just wondering how large a spur gear you needed to go up to in order to get the belt off the motor? Thanks.
    Ron
    Feb 2007
    louisiana
    449
    just adjust the motor,with the 2 screws that hold the motor in
    Apr 2002
    Salinas,California
    516
    Or, you could put a peice of teflon tape on the motor can.
    'Pede 7700Kv
    4-Tec 5700Kv
    Powered by Mamba Max
    May 2007
    9
    Quote Originally Posted by 4tecowner
    I would, but the motor is adjusted as far as it can go. I found out from another board member that I can just use a larger spur gear (93-tooth or 96-tooth) to fix the problem. Have one on order now along with a new pinion to keep the gear ratio correct.
    Sep 2006
    Plattsburgh, New York (way upstate)
    19
    I just installed a brushless system in mine and I'm trying to find the most efficient gearing set-up as well. I'm finding with the 96T spur I'm limited to using a 24T pinion or less. I'm thinking that a better way to go about this is to go with a mid-range spur gear which will allow for more adjustability with my pinion gears. I'm sure this isn't an original idea
    Feb 2003
    Portsmouth, Ohio.
    76
    It's been a while since I've tinkered with my 'Tec. I cannot recall what I changed my gear ratio to. When I get home I'll check the ratio and post.
