Results 1 to 14 of 14
    Nov 2005
    23
    Work in progress and pics
    Here are some pics of my Revo project. Had started and am now waiting for the new Revo 3.3 pieces to make an extended chassis Revo with center diff and rear brake.
    Here are my mods so far:
    OS .18 TM currently with EZ start (getting tired, to be replaced by TRX 3.3, already ordered)
    FOC
    P2 Rockers
    Traxxas Tubes Pushrods (not installed yet)
    Traxxas Tubes Toe links (not installed yet)
    Tekno RC wind mount
    Proline 1/8 wing (dyed black as per Mis' instructions, Thanks!)
    Proline 40 series Wabash (dyed black as above)
    Proline 40 series Crime Fighters
    Proline 23 mm HD Hex's
    Single steering servo (Hitec HS-5945MG)
    Proline steering arm
    Hitec HS5625 MG throttle/brake servo
    Integy MSR6 piggy back shocks with shock socks
    RPM oversized axle carriers (F & R)
    Traxxas adjustable extended rear arms
    RPM RC10GT receiver box
    Xtreme RC silver carbon fiber low CG battery mount
    Xtreme RC silver carbon fiber throttle mount
    RD logics front and rear aluminum skid plates
    X-stiff steering servo saver spring
    x-stiff throttle return spring
    Nomadio Sensor with v2 transceiver (Awesome Radio, great balance)
    Traxxas Resonator single chamber pipe (not shown in pics)
    Proline CrowdPleazer 2.0 by Steve at Zielke Racing (Thanks Steve)
    Future upgrades:
    Revo 3.3 extended chassis (will have it ano'd black or clear?)
    TRX 3.3
    Revo center diff and rear brake kit (gearbox halves too)
    Revo 3.3 chassis brace
    titanium steering linkage (when available)
    Revo 3.3 center drive shafts
    die shock socks and rockers black
    Aluminum hollow balls
    Enough typing, here are the pics:
    http://i36.photobucket.com/albums/e4...4/bd6bef5e.jpg
    http://i36.photobucket.com/albums/e4...4/c8774d9b.jpg
    http://i36.photobucket.com/albums/e4...4/c56a9c1a.jpg
    http://i36.photobucket.com/albums/e4...4/5ee25109.jpg
    Let me know what you think. Thanks.
    Please keep all images to a width of 600 pixels or less. To do this, you must edit the image using an image editor before you upload the picture to your host.
    I have changed the images to links so that people don't have to scroll to read the thread.
    Mis'
    Dec 2003
    Tampa FL
    177
    Why do you still have the easy start?
    Revo, Roto start, motersaver air filter, Failsafe, proline wing, Rd logics dual exhaust, HPI primer button.
    Jan 2006
    Springfield, IL
    174
    Nice. I love the Flames on the body, very nicely done. I still have the EZ-start on mine as well because, well, it's easy! If I took it off and went with something else it wouldn't really increase my lap times so why bother with it?
    Did my wheel just roll through here?
    Oct 2005
    76
    is it better for it to sit that high? mine sits very low...but maybe because the mach 26 is weighing it down haha
    Nov 2005
    23
    Like I said...
    It is a work in progress. The EZ-start is there because I haven't gotten my starter box yet, and I don't feel like using a pull start right now. But, as the weather starts to get nicer here in the NE, I'll have my starter box and backplates on the way.
    Thanks for the compliments on the flames. That's all Steve from Zielke Racing. Thanks Steve!
    It is currently sitting high because I haven't changed the preload on the shocks from when it was a fully laden stocker. I plan on swapping over to the extended chassis, so no use in adjusting this as it sits right now, it's all getting torn down soon.
    I've also ordered a PMB setup system (www.pmbproducts.com) which should be here next week. It's one of the nicest setup systems I've seen, even being cut out for the 23mm hex's, and should allow me to really dial in the new chassis.
    Thanks.
    Mar 2006
    14
    jr1414,
    thats a nice set up.. really really digg'n the paint job.
    Just wondering about the battery mount. Where did you get that ? I cant seem to find anywhere on the INET. How does your fuel tank stay still, because when you remove the stock box, the fuel tanks rest on a hinge on it.
    Also you upgraded to RPM oversized axles? Did your stock ones eventually gave out. I'm asking because I run 23 MM also. Thanks
    Apr 2005
    Omaha, Ne.
    1,734
    Jan 2006
    okc
    2,210
    Looks good
    Hip Pocket Racing
    revo-world.com
    Mar 2006
    14
    Knuck.. thanks for the fast response!
    Jun 2005
    714 OC 714
    81
    here's what i did, i got rid of the glow plug wire and use an ignitor cuz it's hotter, and i use the e-z start to turn the engine.
    wow! look at it go! ...do you think it's dizzy? No trespassing, violators will be shot. Survivors will be shot again.
    Nov 2005
    23
    Thanks for the compliments. Can't wait for the 3.3 pieces. Then I can finish the beast!
    The fuel tank uses an extra mount as in the rear of the tank, there is a hole on the Xtreme RC battery mount for it. I got the mount from a fuel tank rebuild kit, but you can easily substitute or hand make a piece for it.
    I'm not quite happy with how the tank is sitting, I think I have to modify the mount to make the front of the tank lower.
    Nov 2005
    23
    Just a quick update on the project. Have everything now except for the center diff. Once it comes I'll bolt it all together. Till then...
    May 2006
    313
    that is wicked bad i want a body like that
    If its not broken then you arent driving to your ability
    Jan 2005
    cottage grove, minnesota
    669
    nice camper in the few frist ones.
    trx 2.5r, foc, p2 rockers with green in front and tan in back and 50 all around, everything else is stock.
