Results 1 to 7 of 7
    Apr 2006
    Top Fuel 33% Nitro
    Was dusting off a Nitro Tec 4 that my son received a while ago and we were planning to run it this weekend. The manual states that this model should be operated on Top Fuel 10% or 20%. The local hobby shop only had Top Fuel 33% nitro in stock. They said it replaced the previous blends across the board.
    Does anyone know of a product or service bulletin covering this change???
    The fuel can states that it can be used with the 2.5 TRX engine.
    Thanks for any assistance until I can contact customer service on Monday... they were closed today when I called.
    Feb 2006
    Upstate, NY
    83
    First I've heard of it...
    Revo 2.5, RPM A-Arms, pull start, foc, close ratio gears
    Dec 2004
    127
    33% traxxas top fuel
    it is around:
    http://www2.towerhobbies.com/cgi-bin...?&I=LXJCN1&P=M
    FEATURES: Specially formulated for use with nitro cars and trucks
    Ideal for Traxxas 2.5 and 2.5R racing engines
    10% more nitro than standard 30% racing fuels
    Castor and synthetic oil lubrication blend, synthetic oil provides
    excellent high-tech lubrication and rapid throttle response, castor
    oil provides additional high temperature and over-lean protection
    Anti foaming agents and corrosion inhibitors maintain stability
    and peak performance
    Meets Traxxas's and other manufacturers' specifications for engine
    warranty validation
    Tec Pro 3.3, MIP Stinger,Jaco Nitro Shoes, HPI WRX, VARAD Lighting System...... Check up cause I Will bump draft.
    Feb 2006
    In the mountains
    1,633
    33% is fine it just increases wear and u get more power also i doubt traxxas would discontinue the lower nitro cause my lhs is still getting shipments
    Retired RC'r till funds can be found...:(
    Mar 2006
    MI
    4,478
    My lhs still sells 10 and 20%.
    I tried being reasonable, I didn't like it.
    Dec 2004
    127
    I wouldnt reccommend 33% on a stock ride"JMO"...ive used all the fuel traxxas reccommends, and "IMO" Byrons Race 20% (19.00 per gal) is my fuel of choice.....
    Registered User OneBigMan647's Avatar
    May 2002
    Calabasas, CA
    5,579
    Top fuel works great, 20% or 33% in my old 2.5R's. The switch to 33% really gave quite a boost.
