Results 1 to 11 of 11
    Apr 2006
    63
    Reverse, Why Bother?
    MY 3.3 linkage moves when I shift to reverse yet it has only succesfully shifted into reverse one time. Why did they even bother? I have read several comments about reverse problems here. Does anyone have one that actually works?
    Oct 2005
    South Florida
    19,502
    Quote Originally Posted by creepyjackalope
    Your idle must be too high. Optidrive handled reverse problems well, most of those posts are the poor souls who do not have optidrive.
    ME I never use reverse. FOC all the way! Reverse? Nah, just adds weight.
    All Lives Matter
    Sep 2005
    Kettle Falls WA
    274
    As a basher I use reverse all the time, but maybe my driving skills needs improvement
    Tenzo_Racing
    Guest
    +1 on throttle set to high. look at the optidrive when you stop the light should be solid. when you drive it should be blinking.
    Nov 2005
    Southwest Florida
    894
    Quote Originally Posted by Bluetalon
    +1 cough cough I'm with you cough cough.....
    "I Used A Mailbox As A Brake Once...Then I Plowed It Right Over...Hmm Must Be A Supermaxx"
    "People Say UE Is To Expensive, Then Again Never Having To Replace A Broken Part Is Priceless"
    Apr 2006
    63
    You lost me at +1 on throttle....what do you mean?
    Sep 2005
    Kettle Falls WA
    274
    The +1 means he agrees with the other post. I think he ment Idle is set to high not the trottle.
    Tenzo_Racing
    Guest
    OOPS I mean idle DOH!!
    Feb 2005
    Ohio
    330
    The new 3.3 opti drive tranny does not depend on the way the idle is set. The old 2.5 tranny does but not the 3.3. Sounds like a bindind issue in the tranny or a linkage issue(not swinging far enough to engage the reverse gear).
    OPS Powered Mugen MBX5T, Predator build2
    Aug 2005
    b.c.
    82
    like maxxbash said,its probably a simple linkage promblem....
    Feb 2002
    Central New Jersey, USA
    13,880
    I like having reverse available when I need it, and reverse gear is very reliable. As mentioned, if you have a 1st or 2nd generation T-Maxx, you'll need to make sure the idle speed is set correctly. The 3rd generation T-Maxxes (2.5R and 3.3) have the OptiDrive system, which prevents the shift servo from changing directions when the truck is in motion. If you have a 3rd Gen. truck and the servo is moving but the truck will not change diection - you probably have a linkage adjustment problem. The reverse function on my 3.3 T-Maxx has been flawless, and has saved me a lot of walking around when I get my truck in a a situation where it needs to be backed out of.
    Speed costs money, how fast do you want to go?
