Results 1 to 18 of 18
    May 2006
    3,257
    diff question...HELP!
    I just acquired another Jato via ebay, and i had to rebuild the thing from ground up...man what a sight...made me sad....anyway after 4 hours of cleaning and replacing just about everything but the front end i finally finished.
    Now here's my question...I run my other Jato with an MIP ball diff so the stock one is completely foreign to me. After I built the new diff, when i was done one tire would rotate, but not the other...and so forth on each side..now...when i push the spur when the truck is on the ground, both tires move as the engine would move the truck...is this normal? Is this the "planetary" diff style? Can someone clue me in about how this works?
    Keep in mind that the 2 speed and slipper were purchased seperately, taken out of a brand new Jato at my LHS completely new and untouched.
    I was then given the new diff to put in a day later.
    Any help would be greatly appreciated.
    Jun 2005
    CT
    196
    Do you have any diff fluid in the diff? If not, or if it's the stock stuff (which is probably half-leaked out anyways), then that sounds about right. Basically, the situation is that the fluid in the diff is not viscous enough to overcome the friction to turn the other wheel, so it turns the next easiest thing, the spur (Assuming your brakes are really loose). If you put in thick diff fluid, like 10k-50k, you should see the other wheel move along with the one you are turning.
    The stock diff in the Jato is a gear diff. Basically, you have two beveled gears perpendicular to another two beveled gears attached to the driveshafts. Diff oil slows the motion of the gears.
    May 2006
    3,257
    thanks man...so basically no diff lube is almost is like running a "locked" diff?
    Registered User OneBigMan647's Avatar
    May 2002
    Calabasas, CA
    5,579
    No, it should be the exact opposite. Since you know your stuff about ball diffs, the stock diff with the stock fluid is like a ball diff in an EXTREMELY loose setting. If you put around 30k in the rear diff you will get the same diff action as a considerably tight ball diff but with a lot less maintenance.
    Sep 2005
    Cambridge, England
    1,837
    if you hold the spur gear and turn one wheel, the other should turn the other way (i know nothing about ball diffs so i dont know if it does the same thing or not) so if you turn one wheel clockwise, the other should turn counter clockwise. if you turn both wheels in the same direction then the spur gear should turn. what you said if you turn one wheel the other wont turn, if the spur gear is turning then the diff is probably working. try putting the brakes on/hold the spur gear and if the other wheel starts turning in the oppisite direction then its working.
    Jul 2006
    Northern California
    326
    Quote Originally Posted by jato75
    I've talked to alot of Truggy guys and I have tried various silicon thicknesses. The bottom line is that the Jato diff will never perform as a posi-traction or limited slip diff. The only way to get posi-action is to buy a torsen diff. They are very expensive and most of the Truggy guys don't think they are worth it. The Truggy guys deal with changing the fluid in 3 diffs (front/center/rear) in order to get the right action. Basically, changing the
    diff fluid changes how much "diff out" you get. I have a long explanation, but just ask your knowledgeable LHS about "diffing out".
    May 2002
    Calabasas, CA
    5,579
    If you want to try and lock the diff, team associated sells some 300k diff oil. I know there is 500k diff oil out there but I forgot who sells it.
    Feb 2003
    Ohio
    179
    LHS sells a 4 oz. silicone paste. $3.00. I'm using that in a 2.5 diff. Seems to lock up the gears pretty good, but will still allow some slippage. No leakage.
    I tried some 300k.(3/4 oz.$7.00) It's like cold honey! Wanted stiffer yet.
    We'll see how this works out when it gets cold outside. Might strip the gears!lol
    Bus
    Jul 2006
    44
    when you guys are saying inbetween 10-50k can you use shock oil or is that something totally different?
    May 2002
    Calabasas, CA
    5,579
    Diff Oil and Shock oil are both silicone fluids.
    Shock oils range from 10-100wt.
    Diff oils range from 1,000 to 300,000wt. Thus the abbreviation "k". As in 10k for 10,000wt.
    Jul 2006
    Northern California
    326
    Quote Originally Posted by WizBus
    What effect are you trying to get by using such heavy silicone? Hope you're only planning on running your Jato in a straight line.
    Feb 2003
    Ohio
    179
    What I see, when the jato is turning, is the inside wheel always seems to spin up and balloon at lot. My thoughts are, if I can get both rears to rotate equally, it would make it easier to power slide out of a turn with PL Dirtworks.
    A ball diff will do this by adjusting the tension.
    The Maxx uses different weight "grease" lube to accomplish this too. Or a spool.
    I've experimented with 7 different silicone fluids and pastes. So far, I like the paste the best. It still allows the diff to slip a little when needed.
    It only takes a few minutes to pop a different diff in it. (I have a couple spares). Compressed air and a shop rag cleans them up pretty quick too.
    Yesterday, I put this new single speed I built, in the 2.5 with 18/56 gearing and the ultra stiff diff. It needs a D-box or a way better driver now. It's pretty impressive when you get a good powerslide and rooster tails out of a turn once in a while. She hooks up pretty good on dirt!
    Bus
    May 2006
    3,257
    thanks everyone for your comments....i experimented with a couple of different wt. lubes and I just don't like the style of diff it has...the idea that you have to use a different wt. to make your diff tighter kinda stinks...more over the fact that it constantly leaks makes it smell worse. ...i ended up ordering the MIP diff again. That diff rules in my opinion...I've had it in my other Jato for like 5 months now and haven't had to do a thing to it.
    Thanks people.
    Jul 2005
    405
    anyone have a link to the MIP ball diff for a jato? Thanks
    May 2007
    on a hill
    320
    @jato75 when you adjust a ball type diff how do you know if it is to tight or to loose. i'm a noob and have a proball diff so some insight would be very helpful
    May 2007
    124
    Quote Originally Posted by rb_monster
    Here you go: http://www.rcplanet.com/MIP_Jato_Bal..._p/mip1625.htm
    or
    http://www2.towerhobbies.com/cgi-bin...?&I=LXMHB8&P=Z
    If money grew on trees - I'd own Traxxas.
    May 2006
    3,257
    Quote Originally Posted by tommrussell
    easy....the tighter the screw is in the diff, the more tension you'll feel when you rotate the tires while holding the spur. if you lock it, the tires may not rotate at all. that's how i like to run mine...I like all the power straight to the ground....if it's too loose, you may have slow acceleration, a spooling sound coming from the transmission, or it just act very sluggish.
    hope that helps.
    May 2007
    on a hill
    320
    yes it did and thank you , it makes more sense to me now
