Results 1 to 4 of 4
Thread: Flywheel
    Jul 2006
    91
    Flywheel
    My Flywheel Use To Have Teeth On It But Now Its Smooth As An Egg And I Was Wondering Should I Replace It Or Not. If I Dont Replace It What Will Happen, And If I Do Replace It What Wont Happen
    NITRO 4TEC:OS 18TM WITH ALL THE LIGHT UPGRADES
    Jul 2002
    wichita, ks
    1,622
    If you still use the easy start, don't worry about it. As long as it doesn't have a big chunk knocked in it, the balance should still be ok. If you ever decide to use a starter box, you will need a new flywheel. The teeth are what grips the rubber wheel on the starter box. Otherwise replacing it won't help performance, it will just cost you money.
    -Terry
    "The best part of wakin' up....is Nitro" i
    Aug 2006
    Phoenix...Greatest City on Earth
    412
    My question is....why is it smooth?
    May 2005
    Newberry S.C
    408
    Caught between a rock and a hard place
    More than likely a rock or another foreign object got lodged between the flywheel while the engine was running. Like terry said unless you use a bumpstart it should'nt affect the workings of you car.
