Thread: Bulkhead front
    Jul 2007
    South Africa
    26
    Bulkhead front
    Hi,
    Can someone pls tell me what oil/grease to use for the front bulkhead when replacing.Help will be appreciated.
    Andries
    Apr 2006
    Stoke On Trent, Staffordshire, UK
    1,141
    Do you mean the front differential? The bulkhead should not require any grease at all.
    Revo 3.3 mk1, Xray M18MT, LRP Shark MT
    Apr 2006
    1,141
    Bump - to put higher up the list than the duplicate
    Jul 2007
    South Africa
    26
    Yes the front.ok thank you very much for your help
    Apr 2006
    1,141
    Actually in the sealed part of the differential, where the spider gears are, you want to fill that with around 30 - 50 weight silicone diff oil. For the pinion and ring gears, you need to use a small amount of white grease, available from most hobby stores.
