    Nov 2003
    Cape Cod, MA
    151
    recomended weight diff oil
    hey guys, i race on a big oval with a bunch of other guys, the traction is low enough were every one has to use paddles. Its on a beach parking lot, so its a mixture of sand, gravel dust, and medium pieces of gravel every were (1-2" pieces). I seem to be turning fine but under hard acceleration, the truck veres either to the left or right. Would i benifit from a thicker oil to give me a possi like feal? such as 50k weight, or should i go lower than stock to lets say 7k weight. The manual says
    Differential Tuning:
    Use higher viscosity
    (thicker) oil for:
    More power to the wheels
    with the most traction.
    Racing on low-traction
    smooth surfaces .
    Better performance for
    climbing on uneven terrain.
    Using lower viscosity
    (thinner) oil for:
    with least traction.
    rough surfaces.
    not sure were i fit in, if anything its a low traction with rough terain, but i just feel that a thicker weight would fix my truck veering to the angles. Thanks
    Feb 2007
    Loveland, Co
    333
    I think if you try thicker oil it might help. I run 30k in mine and I like it. If it pushes too much in the corners you can always go back to what you had. The good part is it’s cheap to try several different weight oils and it doesn’t take long to change.
    It would recommend you buy a new gasket set or two just to have on hand. They are only $1.45.
    Gasket
    Oil
    Jun 2007
    Erie Pennsylvania
    237
    I just put 60k in mine, and so far I like it. Diffs enough on the street for me, and has a pretty close to posi feel. I'm still trying to figure out this MIP ball diff. been months and I still don't have it put together.
    Silly fast Jato 3.3
    Nov 2003
    Cape Cod, MA
    151
    iv heard many poor reviews of the mip ball diff, i have been told though that the stock one is excellent.
    Mar 2007
    western NY region
    2,097
    i've been using 30K diff oil for a few months now and i like it allot better than the stock fluid...and as DavidS302 mentioned be sure to have a couple of diff gasket sets on hand for when you change your diff fluid out...
    "Growing OLD is mandatory, Growing UP is optional"
    Jun 2007
    Erie Pennsylvania
    237
    Quote Originally Posted by bbike
    We'll soon find out. After about an hour I figured it out. I've got it locked, which is what i wanted, and its adjustable without makin a mess! I'm running 60k in mine now, and I can't really complain there either. had absolutly no blow outs on the inside tire while doing donuts.
    Silly fast Jato 3.3
