Page 1 of 5 123 ... LastLast
Results 1 to 40 of 184
    Nov 2005
    Guernsey, Channel Islands
    2,316
    Latest Mod's for GF's Maxx
    Heres some of the latest purchases for my girlfriends Maxx.
    Traxxas 7075T6 4mm Race Chassis (I bought this from George16)
    Traxxas DCResonator with Stock header
    Dace 7075T6 Nickle Plated Aluminium Motor Mount.
    I have polished the chassis with Wet/Dry sandpaper up to 1200 grit, I think it still needs work so going to get some 1600 and 2000 grit then use some aluminium polish on it to make it like this!
    I've also ordered a full 3.3 Spec Driveline upgrade. Just waiting on there arrival.
    http://www.unlimitedengineering.com/...achmentid=4007
    Feb 2002
    6' to 8' feet below sea level @ Elev. 0'
    1,302
    Next purchase, get a pre-nup.
    Turn em and burn em... Screwloose
    May 2006
    6,988
    Looking good there Jonny!! You can also try some aluminum wheel polish in tryin gto get that nice bling shine . If you have a rotary tool like a dremel, you can shine that bad boy in no time at all. Keep in mind though that it's aluminum so a lot of heat can be generated while polishing it with a rotary tool.
    Jul 2007
    Ontario, Canada
    3,985
    looks good, be sure to show us more pics with everything installed
    Werks powered Mugen MBX6T!!!!
    Sep 2007
    897
    where did you get that engine mount or did you make it yourself?
    Nov 2005
    2,316
    Oct 2007
    MI
    106
    SWEET! just one question? to de-anodize the chassis did the guy you bought it from chemically strip it or just sand/scotch brite it? just wondering as it would look pretty cool under my 3.3. thanks
    May 2006
    6,988
    Quote Originally Posted by DougsT3.3
    Rusty bought the chassis from me. I used oven cleaner in a yellow spray can and then wet sand it a bit. I was going to polish it with an aluminum wheel polish using my dremel but I never get around to it so I sold it .
    Where in MI are you from? I'm from Troy, just outside Detroit.
    Oct 2006
    georgia
    3,299
    very nice thats going to look awsome on the maxx
    65mph n rusty 13 more mph to go :)
    Oct 2005
    South Florida
    19,500
    Smart man getting the G/F involved with your hobby avoiding the nagging sessions of "So when are WE going to get time together" and "You spend more time with your Truck than me" lolll
    That's exactly why I got my wife and kids involved.
    All Lives Matter
    Oct 2007
    MI
    106
    hey george16,
    I'm up in east tawas. use to be in highland(by milford).I usually drive my truck up on the old wurtsmith air force base-- tons of open space and some good bash spots.
    I think I'll try that oven cleaner on my chassis to help set it apart from my co workers' trucks
    Nov 2005
    2,316
    Been doing a bit of work on it.
    Put the front and rear end on it to work out were I can put everything. Also started working out my options for direct pull throttle and started making the linkages.
    I'm waiting for 3.3 Knuckles, Shafts and Turnbuckles to arrive. A full set of Purple RPM arms and bulkhead braces and I'm going to order a tank like the one on it but new as thats my Supermaxx tank and I'm also gonna get some Ofna Ultra Front shocks for it.
    I've also ordered the Crazy Nut brake kit and UE brake hex to go along with UE centers.
    I still need to get me a 3.3 or similar engine, 3mm diff cup (I already have a 3mm ring gear), Aluminum braces and the newer 4 screw style diff cases.
    May 2006
    6,988
    Looking good Jonny. Did you have to drill a new set of holes for the fuel tank or did the holes I drilled line up?
    Nov 2005
    2,316
    The ones you had lined up just fine I need to shim the posts abit though as the tank will be pushing hard into the chassis otherwise.
    May 2006
    6,988
    Quote Originally Posted by Rusty Noob
    You're right. There should be the hard plastic spacers between the aluminum posts and the chassis.
    Fuel tank posts and spacers.
    Or you can just cut some hard plastic or rubber gasket and drill a 3.2mm hole for the screw to go through .
    Nov 2005
    2,316
    Yeah I've got just the stuff for the job hehe.
    Oct 2007
    1,722
    Nice work. I'm also thinking about upgrading my stock chassis to a stronger, lighter one, but I'm just wondering which one I should get.
    O.S. 18TM, Jeep body, Ofna failsafe and Bandit VXL
    May 2006
    6,988
    Quote Originally Posted by Professor
    I'm biased on the Dace Predator and Trx racing chassis. However, I was able to create a replica of the Trx racing chassis on a stock 4mm 6061 chassis using my dremel. I even drilled holes so I was able to have the same layout as my Dace chassis.
    3.3 with Dace chassis:
    2.5R with modified 4mm stock chassis:
    Direct pull throttle setup:
    Nov 2005
    2,316
    There are so many decent chassis out there its hard to advise you. Are you after big block or small block? Extended wheel base or not?
    Nov 2005
    2,316
    Some other new parts came in!
    The RPM Arms and skids need a good bath as there a little bit dirty but they should be as good as new soon!
    Sep 2007
    799
    hey rusty what axle carriers are thoose.
    i might be back with a vegence
    Jul 2007
    orlando, florida
    316
    they are the 3.3 carriers (3.3 maxx or Revo)
    Nov 2005
    2,316
    Got the all the stuff installed! I also received some RPM shock towers but I ended up ordering 2 sets of skids! Because I bought from 2 different people I thought I had asked one for arms and bulkhead braces and the other for skids and towers, turns out I asked for Arms and Skids and Towers and skids lol!
    Just to say thanks to DickyT for the arms and skids, great seller, very honest and great communication and also thanks to billytrucks on e-bay. Billytrucks is one of the best EBay sellers as he doesn't act like a robot that other big RC sellers do such as rcwaffle.
    I'm gonna get this stuff linked below as well
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=140102000485
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=190135473563
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=290108187206
    Nov 2005
    2,316
    I can't wait to get this one up and running! It will be interesting to see how it compares to my Big Block as the Big Block maxx is definately heavier with CVD's and all aluminum!
    What do you think will win in a straight up drag?
    3.3 with the Resonator and Lightweight drives
    or
    .26 Big Block Supermaxx all Aluminum with Heavy Steel drives.
    Oct 2007
    Boo-Val, Fl
    1,434
    Rusty Noob,
    This may sound like a newbie question, but are those RPM arms plastic? If not, then the finish looks matte and plastic-like.
    Also, how did you figure out the Toe & Camber? Do you have some kinda alignment tool?
    Nov 2005
    2,316
    The arms are plastic, this T-Maxx is a "cheap" one for my GF to use so she can come bash with me. I do all my alignments just by sight, I havent done this one yet as I dont have the turnbuckles.
    Hope that helps!
    Oct 2007
    Boo-Val, Fl
    1,434
    Cheap, eh?! I notice that you have that word in quotation marks...
    All of that pink and purple! Do you think you'll be able to see the fuel through that pink fuel line? Dare I ask what body she will be running?
    Nov 2005
    2,316
    I say "cheap" because its costing less than half of what my Maxx did lol. Probably wont be able to see the fuel through it but I'm used to it as I use some Royal Blue fuel line which is completely opaque, Never had probelms and if I do I just replace the fuel line, I bought the blue on a 50ft spool hehe.
    Jul 2007
    ohio
    1,947
    lookin good rusty, that will be the ultimate qt time, runnin the maxxs
    everything i own is brushless and lipo baby
    May 2006
    6,988
    Looks real good. I bet her tmaxx will outrun your supermaxx . By the way, what center shafts are you going to use?
    Nov 2005
    2,316
    UE Dogbones of course I really hope she won't outrun me! If she does I'll just sell up the Sportwerks .26 and go with the RB 728 :P
    Jul 2007
    ohio
    1,947
    yep definatly cant have the woman showin you up
  33. #33
    Nov 2005
    2,316
    Just got my CNR Brakes in the post today!
  34. #34
    Oct 2007
    Boo-Val, Fl
    1,434
    Dual discs...didnt know a maxx needed that kinda stopping power! But then again, I havent even reached top speed with mine yet. Is it really necessary? (Yes, newbie question once again)
  35. #35
    Sep 2007
    799
    wish my girlfriend would let me build her a maxx
  36. #36
    Oct 2007
    Boo-Val, Fl
    1,434
    I'm lucky enough that my girlfriend will let me HAVE my T-Maxx! But if she didnt, she wouldnt be my girlfriend!
  37. #37
    Nov 2005
    2,316
    Dual brakes arent 100% nescassary but I'm gonna slowly build that tranny into an OTB/Super6 combo then transfer it to my Supermaxx which will bombproof the driveline.
  38. #38
    Oct 2007
    Boo-Val, Fl
    1,434
    Oh..thanks for the enlightenment. So I take it that you race with your SuperMaxx?
  39. #39
    Nov 2005
    2,316
    Nawr not yet, still just bash it around, hard!
  40. #40
    Nov 2005
    2,316
    More parts on the way!
    2 Sets of these shocks http://cgi.ebay.com/ws/eBayISAPI.dll...m=110182528875
    This fuel tank http://cgi.ebay.com/ws/eBayISAPI.dll...m=110187345459
    This Fuel Tubing http://cgi.ebay.com/ws/eBayISAPI.dll...m=290108187206
    These Chassis Braces http://cgi.ebay.com/ws/eBayISAPI.dll...m=260181211170
    This Linkage Kit http://cgi.ebay.com/ws/eBayISAPI.dll...m=250154416288
    This Antenna Tube http://cgi.ebay.com/ws/eBayISAPI.dll...m=140102000485
    Can't wait for it all to arrive and it will be a complete rolling chassis
