Thread: Jato flat packs
    Jan 2008
    Andrews Tx
    332
    Jato flat packs
    Okay will any 5 cell flat pack work? Found some integy ones for cheap and lots of other brands. Trying to keep cost low.
    Preetiness is a light switch away
    Apr 2007
    California in the YAY AREA!
    4,343
    ok, it is afew dollars cheeper than traxxas one but it will last awile if you charge it right, I charged mine too high and it doesn't hold a charge but if you get a good rate of charge it will be good. Oh whell here is the link
    No more money for rc trucks I got 1:1 truck
    Jan 2008
    New York
    443
    use the one that traxxas suggests they are better made.. but that IMO...
    Speed is the only way to go.
    Apr 2007
    strasburg,PA
    138
    i use the one from traxxas and it works real well
    -Jato2.5
    -Micro-T
    -Redcat Volcano STX (hah)
    Mar 2007
    western NY region
    2,097
    i use the the traxxas Flat Rx Power Pack (<-- click!) & TRX Power Charger (<-- click!)...have used them both for a year now and have always worked flawlessly...the charger even comes with an adapter to charge your 7.2v stick pack for the ez-start wand...also note that you can use the jatos on-board charging system with the flat pack...there is an extra wire in your receiver box that has a black connector on the end that is not hooked to anything (this is on 3.3 jato only)...simply run that wire under the chassis top plate towards the front of the truck by the exhaust pipe hanger mount and antenna mount...there is a rubber plug there...clip the connector up under that spot and thats your charging jack...
    ***another note***
    be sure to make sure the trucks power switch is in the off position before attempting to charge the battery...if you fail to make sure switch is in the off position you risk the possible chance damaging your receiver and/or servos...
    "Growing OLD is mandatory, Growing UP is optional"
    Jul 2006
    Montana
    5,087
    Jan 2008
    28
    I ordered the Traxxas one from Tower, but I grabbed an extra one from my LHS and it is an OFNA. I haven't seen any problems yet.
    May 2007
    Memphis, TN
    116
    I ordered this one:
    http://www3.towerhobbies.com/cgi-bin...?&I=LXSFS4&P=7
    Fits perfectly in the middle compartment!
    Jan 2008
    Andrews Tx
    332
    Alright yeah that was my main questions if they would fit/work the same as the revo packs Thanks
