Thread: Clean up
    Feb 2008
    24
    Clean up
    just a thought, since the new emaxx is water resistant is it possible to wash it with a hose? not a power washer just garden hose and some cleaner. should make clean up a snap. any one try this?
    Feb 2008
    Saskatchewan Canada
    49
    if I am not mistaken it says it is okay to use a hose right in the manual under cleanup
    Mark
    Jan 2002
    Kannapolis, nc
    83
    I use low pressure from a hose with brush and spray cleaner. Then use air compressor to dry.
    Feb 2008
    8
    Yup!
    TT
    Jan 2008
    126
    I've used a hose and a shower. Just make sure the pressure head is low. I don't have a compressor, so I angle the truck sideways and put a oscillating fan right in front of it on high (after a towel dry).
    I also use compressed air on the areas by the servors, ESC and receiver. I try to be conservative though as that can get expensive. I will probably end up buying a small compressor when I get an airbrush.
    Res Ipso Loquitor
    "Let the good times roll"
