Results 1 to 23 of 23
    Jul 2008
    Detroit, MI
    162
    Best Replacement for Titan 12t
    What do you guys think the best replacement for a Titan 12t is?
    I only have an XL5 and a 3000mah 8.4v batt, (I plan on getting another 4600mah 8.4v as well)
    Obviously they burn out pretty good and fast, so I was just wondering what you guys have upgraded to (less than going brushless)
    My price range is $50 or less but I will go up to $60 if needed.
    Thoughts? If I left out any information, just let me know, I'll be on the forums for a few more hours before turning in.
    $600 (ttl) in my E.Rusty
    $60 (ttl) in my N.Pede
    Jan 2007
    Crystal, MN
    1,869
    Best Replacement
    Just make sure you replace the Bushings and Brushes when the time comes around.
    BMW E21 323i.. My baby.
    Jul 2008
    Detroit, MI
    162
    So would more turns be faster than less turns, I thought I saw somewhere that less turns were better, but I'm not sure.
    Jan 2007
    Crystal, MN
    1,869
    Ok. Well, the Titan 12 T is a 550 sized motor, so it has a longer can length and armerature. So, a 12 Turn 550 is comparable to a 540 sized 15 turn motor. The more turns there are(higher turns) equals more Torque, where as less turns equals more speed. The problem is you can gear reallly low turn motors to fit a rusty, and they overheat. Also, the lowest turn you can run on the Xl5 is a 15 Turn.
    1,116
    i would go with the 17t or 15t orion pro formula bb motor not the bushing one. i think it is 39.99 from tower but when i ran it th results where great. I also had one of there 12t motors but your xl-5 esc can not handle that motor.
    Jul 2008
    Detroit, MI
    162
    Quote Originally Posted by boostedg60rado
    So, If I want the 15t, I would go with this one right? It's rebuidable right? Otherwise I'll just end up in the same boat. It seems all the Team Orion Motors are, but I just want to make sure...
    I want torque, but i still want to get some pretty good speeds as well...
    http://www3.towerhobbies.com/cgi-bin...?&I=LXJAJ4&P=V
    I really do appreciate all your guy's help with this, I only got into R/C about a month ago. Stadium truck RC anyways...
    Jan 2007
    Crystal, MN
    1,869
    Different Replacement
    The Ball Bearing Version. Buy this one over the Bushing one.
    As for speed, they will get close to the same, i would say the higher turn since it will be easier to gear and not near as hard on the ESC.
    Jan 2008
    Kzoo Michigan
    1,576
    yeah, I got a 27 turn to do close to 30mph, soooooooo........ it was geared waaaaaaaaaaaaaaaaaaaaayyyyyyyyyyyyyyyyy to high.
    Jan 2007
    Crystal, MN
    1,869
    Wow. Thats amazing. What kinda gearing do you have?
    Jun 2007
    oregon
    661
    i agree with rocky for the replacement
    Jul 2008
    Detroit, MI
    162
    So the 15t is rebuidable right?
    and why cant i find that motor on the team orion website?
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    37,468
    Yes, the Pro BB version is rebuildable.
    The motor is on their website, too:
    http://www.teamorion.com/Products/Br...Wound+Modified
    Jul 2008
    Detroit, MI
    162
    that is not the team orion website i was looking at, lol
    thanks cooleo, I've decided to go with the 15t Bearing... As soon as tower gets it in stock, but i'll look elsewhere too, not sure if my LHS has it, and they closed an hour ago, so, I'll have to wait then...
    Traxxas Marshal
    Mar 2003
    37,468
    Don't forget to pick up a 13-tooth pinion gear for the motor. I'd probably pick up a 14-tooth as well if you are still using Rustler sized tires.
    Jul 2008
    Detroit, MI
    162
    Quote Originally Posted by cooleocool
    Okay, thanks, I'll get the 14 then, thanks man
    what about a different spur, can i just keep the stock one?
    Jul 2008
    Detroit, MI
    162
    Jan 2006
    Saco, Maine
    402
    That pinion wont work its a 32 Pitch and the rustler uses 48 Pitch you would need something like this http://www3.towerhobbies.com/cgi-bin...?&I=LXEX12&P=7
    Jul 2008
    Detroit, MI
    162
    Quote Originally Posted by traxxasfanatic
    alright, thanks man
    now you see how big a n00b i am, :P
    Ontario, Canada
    370
    I'm just saving up to go brushless, my titan is almost dead, bearings need oil regulary, and i've had it up to 200 a few times. had over 30 runs with it so in comparison to some it's not been to bad. I figure since over this time i'd have to buy brushes, cleaning solution, take it in to get lathed from time to time or buy one.. the ease of BL started to sway me.
    Bandit MM4600 things are gonna break
    Traxxas Marshal
    Mar 2003
    37,468
    Quote Originally Posted by Monkie
    The stock spur will work just fine.
    Apr 2007
    Kamloops B.C.
    937
    www.t-bang.ca. nice motors
    if ya can't roam wit the pack go play wit the pups
    Feb 2008
    "They call it paradise I don't know why...
    2,172
    I think you'll be fine with a 17 or 19 pinion depending on conditions.... I've run 23 on asphalt before...
    Porsche wins 24 hours of Daytona for the 21st time
    Jul 2008
    Detroit, MI
    162
    okay i know everything i need to know now, thanks everybody....
