Results 1 to 15 of 15
    Oct 2008
    139
    Truck wanders a bit on high speed runs
    I have noticed that my truck seems to wander on high speed runs either down my street or out at construction sites. Truck is stock. I checked the steering trim and the wheels are pointed forward. I am going to try the push rods on the outer holes tomorrow as well. Any other suggestions?
    Jul 2005
    St. John, Washington
    2,665
    it wanders beack and forth because the tires will baloon up. every truck i have ever had does this
    2010 www.montecarloss.co.nr
    Oct 2008
    139
    Yeah, I mean its not a huge problem, I just didn't know what would be a fix. I just moved the push rods out which lowered it quite a bit so maybe that will help.
    Feb 2008
    Wilson, NC
    1,259
    You could try a little bit of toe-in. It will help stabilize the truck some.
    Revo Mach 427/Single Speed
    Slash Stock-2S LiPo
    Oct 2008
    139
    Quote Originally Posted by xtcvapor
    Toe in on the front or rear.
    Jul 2006
    Canada
    6,323
    If you dont have a wing mount i highly recommend that, it will help keeping the rear on track over 40mph.
    World fastest E-revo 91.2mph / Revo 75mph
    ABmods
    Oct 2008
    139
    Hmm, I didn't think about that. I think a wing, lowered push rod location, some stiffer springs, and maybe some sway bars might help me out a bit.
    Jul 2006
    Canada
    6,323
    Last time i was trying to beat my record, i was spinning out at WOT at 60mph without the wing. And was going straight with it.
    ABmods
    Oct 2008
    139
    Yeah, I might just be worrying about nothing. I am new to this and I guess I kinda figured you can gas it on the straights and just watch. LOL But, you have to drive it and hold it steady.
    Feb 2003
    Texas
    2,080
    Toeing in the front will make it a bit more twitchy, if you toe them out a degree or so it should calm it down some. Keep in mid that this isn't a "road racing car" and will not handle like one.
    Oct 2008
    139
    I might just have to practice a bit more. Check out the following vid. I had trouble in the straightaway with the jumps quite a bit. It was hard to see which way the car was wandering so I would hit the edge often.
    http://www.youtube.com/watch?v=cGRbYz_GY-o
    Aug 2005
    Northern VA
    1,366
    does that track have obstacles along the straight.. looks like tree trucks with tires around it... that could be ugly..
    Is there life without a revo in this world........
    Oct 2008
    139
    Yes! I thought that was crazy. I mean I couldn't go fast there because those things would have torn my truck up.
    Registered User
    Feb 2005
    Your Imagination
    185
    Be sure to check your alignment. I was having that problem, but I knew I needed to do a full alignment. After that its straight as can be.
    I set mine for 1deg out front 1 deg in rear and 2 deg pos camber. Sticks to the ground pretty whell.
    Oct 2008
    139
    I might sit down and do an alignment tonight. I had her up and running down the street with the new lowered stance and it runs good.
