Results 1 to 15 of 15
    Apr 2007
    In a box on Hwy 64.2 - Bashin' With Mike, Pat & Brad. hey i didnt start this.
    7,488
    waht do i ne4ed to do to waterproof my mamba max?
    okay i really wanna run my slash in the water again. i am running a mamba max 5700 and dont wanna switch to anything else. so what needs to be done to run the esc without needing to worry about water?
    ADDICTED TO THE TWILIGHT SAGA
    May 2007
    Sandy, Utah you can find me at the construction bash site a lot
    1,773
    Some have had luck using plasti dip... Make sure you get the thick kind. Possibly a tupperware? Just an idea.
    Agree with slowenufs sig wheres the new 4 tec?
    Apr 2007
    7,488
    i would prefer minimal work. mostly cause it would mean fewer things could go wrong.
    Traxxas Marshal
    Mar 2003
    Wherever the road takes me.
    37,735
    Didn't people last winter just cover the USB port up with some tape?
    Apr 2007
    7,488
    not sure. think i should try that?
    Traxxas Marshal
    Mar 2003
    37,735
    That's what I recall seeing people do with their Mamba Max ESC's. I'd run a search in the Stampede and the Rustler/Bandit forums for waterproofing the Mamba and see what comes up. You should be able to find a few posts on the subject.
    Apr 2007
    7,488
    how bout i jsut take the easy way out and call castle?
    Traxxas Marshal
    Mar 2003
    37,735
    I suppose that would work as well.
    Oct 2008
    mississauga,ontario, canada
    162
    The mamba max esc is absolutly waterproof. the only thing you have to do is cover the usb port with electrical tape. As for the motor, they are pretty much waterproof. So everything should be fine. You can also call CC and ask them.
    New T Slash:)
    Apr 2007
    7,488
    i talked to castle and they told me that it would be best not to try to run it in rain and snow.
    Oct 2008
    162
    WHAT?!?!?! no way! i called them a while ago(like 2 months?) about my mamba max 4600 asking if it was waterproof and they guy told me that the esc is waterproof IF u cover the usb port(which i already knew) and that the motor was already waterproof because the coat it with "something". I asked him why they don't sell them as waterproof or water resistant and he told me it was for legal reasons, ya bogus. lol
    New T Slash:)
    Aug 2007
    Fremont, Ca.
    944
    Lets face it, electronics and H2O do not tend to play nice together and can even be dangerous. If you use some common sense (does that exist anymore) you should be able to use your mamba max in the snow and wet environments with minimal risk of damage.
    The circuit boards are pretty well insulated against moisture with the exception of the usb port as others have mentioned. If you seal the usb port you should not have any problems unless you completely submerge the esc in water. If your going to expose the esc to lots of water or snow it's a good idea to cover it to prevent excessive moisture reaching the pc boards. A simple yet effective solution is cover the esc with a balloon. After your done be sure to let the esc dry completely before using it again. The heat it generates during use will evaporate small amounts of water fairly quickly but when it's cool moisture can settle on the components and cause problems.
    [QUOTE=Billstmaxx]if the water can't get out how does it get in??[/QUOTE]
    Oct 2008
    162
    or just plasti-dip it as a permanent waterproofing method. After i called CC i still plasti-dipped my esc beacuse i wasn't going to risk it.
    New T Slash:)
    Sep 2008
    2,121
    what about waterproofing a vxl
    Race-bred SSC 4x4
    Durango DEX410
    Oct 2008
    162
    i replied to ur message, check ur inbox
    New T Slash:)
