Results 1 to 4 of 4
    Bad Kreuznach, Germany
    486
    Slash Bearing Kits
    Looking for a good set of sealed bearings. Looking over the blown up sections of the Slash I've found the following:
    5x11x4mm (8) - Wheels
    5x11x4mm (7) - Transmission
    5x11x4mm (2) - Optional (Motor-Velineon)
    5x8x2.5mm (4) - Optional (Aluminum Bellcranks)
    5x8x2.5mm (4) - Optional (Wheelie wheels)
    - Have I missed anythng?
    - Can anyone recommend a good company? I've researched Boca Bearing and Acer racing...
    Thanks.
    Aut viam inveniam aut faciam
    Aug 2004
    105
    Check out Avid.
    http://www.avidrc.com/
    Registered User
    Apr 2008
    Bremerton, WA
    1,108
    I think you got everything. Since you are going through the trouble of opening the trans, here's a suggestion - Since the trans case is fairly well sealed, you can use bearings without the dirt seals on any bearing that isn't open to outside the trans case.
