Page 1 of 2 12 LastLast
Results 1 to 40 of 45
    Oct 2006
    119
    VXL vs. Castle Creations
    I have upgraded my son's Stampede over the past couple of years and it now has a Castle Creations 5700 kv motor with Sidewinder ESC.
    I am really impressed with how it runs now and want my own Pede!
    How does the performance of the stock traxxas Pede with the VXL compare to the setup I have in my son's? We will both run the same batteries.
    Feb 2008
    sterling hts MICHIGAN!
    2,034
    sidewinder is faster, vxl is slower, but thats just because the kv is different and the vxl is water "resistant" so it can get a slash or two of water, but a side winde isnt as resistant
    if you want me to i can break your truck for free!
    Jul 2008
    Houston, TX.
    869
    I have a VXL and Sidewinder. I like them both. I have the sidewinder 4600 because I wanted the option of running 3 cell.
    When we run the VXL and the sidewinders the vehicles are very close. I like them both but I like being able to program the sidewinder. The brakes work way better the way I have the sidewinder setup and I like the 25% reverse and such.
    RC Turnbuckle Jr. rjm2519's Avatar
    Feb 2008
    Fl
    3,062
    I have a vxl and I like it just fine, but it would be nice if the reverse wasn't 100%. I am thinking about using a sidewinder for my next brushless system as well. It is a bit cheaper, there a lot of good things said about it on here. I know I don't need the MM or anything like that I will probably stick to nimh. Speed is nice but is not all it is cracked up to be, my rustler is fast enough.
    I mostly like the performance on the track with the brushless, even with a 6 cell. How does the sidewinder do on the track?
    Donít handicap children by making life easy
    RC Turnbuckle Jr. asheck's Avatar
    Nov 2007
    Kansas City
    7,360
    I take it you have proof of this? Because that is not the case.The kv of the motor actually has less to do with the speed,then the power the esc will put out,and the power your batteries will put in.The sidewinder is a low amp esc rated at 70amp constant.It physically can not put out as much power as the VXL , and will not run the 5700 on 3s Now depending on your batteries you may see little to no gain using a VXL esc,or if you have capable batteries it would be a noticeable difference.But the fact is either puts out plenty of power to put a Stampede on it's lid.
    _
    _
    _ 3 lines are all that's allowed in a sig.
    Oct 2008
    new hope alabama
    80
    i would do the sidewinder over the vxl because of the castlelink programing. also, the vxl is known for having lvc problems and button sticking problems.
    Mamba monster E Maxx
    Mamba max rustler
    Jan 2009
    110
    I have a velineon system, Mamba Max with 5700 and Sidewinder with a 5700.
    I like the Castle ESCs because you can make so many adjustments with the programming. In my opinion the Castle ESC's are more versatile than the Velineon system.
    Maybe it all boils down to preference because I like all three systems.
    So I guess I didn't answer your question I just told you my opinion.
    The Castle systems are faster because the motors are rated higher. 5700kV vs 3500kV.
    My Desert Truck outruns my Rustler.
    Nov 2007
    Kansas City
    7,360
    That is only if they are geared the same.There are obviously many variables that you have not come to understand yet.Like the fact that you run much higher gearing with the vxl motor,to achieve higher speeds.I'm running a 2000kv motor in my E-revo,that thing must be a snail A 57mph , backflip from a standstill,launch 10 feet in the air kinda snail.
    _
    _
    Dec 2006
    camillus, ny
    2,850
    Quote Originally Posted by rjm2519
    the sidewinder is a good esc just not rated for as many amps as the vxl esc or the mamba max, both the castle 5700 and 4600 kv motors are faster than the stock vxl motor on 7.4 volts. the 5700 is not recommended for 11.1 volts at least not with the sidewinder esc, i would think that the 4600 would be faster on 11.1 volts than traxxas's 3500 vxl motor, but i do know traxxas's vxl motor is built better than my 5700 castle motor.
    Man i need more than 50 characters.
    Nov 2007
    Kansas City
    7,360
    Good grief people.The kv's do not make the motor faster,especially when your crossing brands.You will be lucky to break 45 with a 4600 motor.Where people have broke 50 with a vxl motor.On 2s.The vxl has been clocked over 70 mph in a Stampede on 3s.Neither of the other motors have come close,at least that I have seen.The 5700 and 3500 will run close to the same speed on 2s,but they must be geared very differently.If I must I'll go into some technical terms,but that will have to wait till morning.
    _
    _
    Jul 2008
    Houston, TX.
    869
    Quote Originally Posted by asheck
    Noche Noche, or night night. You need to write it up, and save it somewhere so when it comes up again you can just paste it in or reference the link. You probably already thought of that or do that, just my 2 cents.
    Nov 2007
    Kansas City
    7,360
    Thats just it,it never comes up,anymore .What I'm saying is very common knowledge,do a search on the Rusty forums and you'll see what I mean. Good night.
    _
    _
    Dec 2006
    camillus, ny
    2,850
    well thats in my experience, in my truck with a decent gearing 17/86-22/86 on 2 cell lipo the 5700 was all around faster than the 3500kv vxl motor, and faster than my 10.5ss with a gtb. just saying that those were my results running in the same conditions with similar temps. yes any thing can go fast but how hot will it get. when geared high on 2 cell my vxl ran hotter than i would like it to.
    Jul 2008
    Houston, TX.
    869
    Good night and I will go take a look later. Been on the computer too long today making my first wmv.
    Aug 2008
    Orlando, Florida
    50
    The sidewinder esc is superior due to the tuning ability with a usb cord. The vxl motor is better than the castle motors because it runs with a very cool temperature. Sure, the castle motor may spin faster, but with the correct gearing on each motor to get the same comfortable temperature zone, they will go the same speed.
    Feb 2008
    Fl
    3,062
    I think the vxl motor is pretty good, I ran have run mine geared 28/83 on 9cells and it was plenty fast every bit of 50mph and the motor never broke 130* with the lid on and the esc was at 113* battery was between 120-130. And honestly I don't feel like I am missing anything with the tuneability I just adjust my finger. I just was thinking of a sidewinder cause it is cheaper than the vxl, I like plug and play not plug program and play. I guess another vxl it will be.
    Sorry 8pede8 but IMO tuneability is not as important as ease of use and powerhandling ability, not to mention the vxl esc can run just about any motor out there.
    Nov 2008
    606
    Well, don't forget that you can mix and match these. The Sidewinder or Max ESC with the VXL 3500 motor might do you well.
    Feb 2008
    Fl
    3,062
    Yeah but then I have to buy a motor seperate from the esc it is easier to find a combo. Will the sidewinder run brushed/brushless/sensored brushless too?
    Dec 2006
    camillus, ny
    2,850
    every thing but sensored.
    Nov 2007
    Kansas City
    7,360
    Actually it will run a sensored motor,but it will do it like a sensorless.
    _
    _
    Nov 2008
    606
    The SW will handle any brushed 540 motor in foward only mode, and 19 turns or more with reverse mode.
    Dec 2006
    camillus, ny
    2,850
    thats good to know, will that work with any sensored motor on a sensor less esc.
    Nov 2007
    Kansas City
    7,360
    As far as I know yes.But I have seen multible posts from CC techs saying that there 's will.I believe all the sensor does is relay info to the controller,rotor position,temp and that kind of stuff.It doesn't actually have anything to do with the motors ability to go.
    _
    _
    Sep 2008
    Was there, now here.
    2,434
    I think a sensored setup just makes it smoother from a stop, less "cogging"
    RustyVXL, HPI RS4 Rally, RC18MT
    Mobius1 crashed!
    Feb 2008
    Fl
    3,062
    yeah stamjato hit it on the head, sensor helps low speed and smoothness, seems like the vxl is still more versatile. Like I said I am not looking to deal with programming and all that nonsense I just want to plug and play and let my finger do the adjusting.
    Nov 2007
    Kansas City
    7,360
    The main thing the sensor does is tell the esc rotor postion.There are 3 phases with brushless,they can all be positive or negative.Depending on where the rotor is,depends on which phase sees what.With a sensored the esc always knows exactly which phase needs what.The sensorless depends on receiving it's feedback from the actual wires.Therefore until it starts to move it's not sure what needs what and seems to get confused at very low speed crawls.But since putting the most recent update on my MM,it is now very smooth at very low speeds.I'm not willing to say as good as sensored, but It was a huge difference.That is a very nice thing with the MM, sometimes the updates can make huge changes.
    _
    _
    Nov 2016
    Atlanta, Georgia
    943
    Yea..... I love the fact of water resistance, my castle system went up in smoke because there was mist outside :/ I have been using velineon ever since then, been carrying for 8 months and only lost reverse for a short time! I don't know what's up with those people who say it's not durable.
    Own: Slash 2wd "rigged edition" (original brushed and then ur became a Frankenstein on drugs, slapping high performance parts into it!)
    RC Qualifier WonderMelon's Avatar
    Mar 2016
    Myerstown, Pennsylvania
    957
    Well with my experience, Vxl isn't as durable. My Vxl motor blew up. My castle creations hasn't. Now I'm comparing a tenth scale motor to a eighth scale motor.
    Dec 2015
    Houston, TX
    11
    Quote Originally Posted by Peeeenuuutt View Post
    I ran my VXL ESC through a lick of water and the button got stuck in the "down" position. All it did from that point on was cycle through training, sport, and race modes whenever I turned it on. I had to throw it away. This is just my experience.
    Dec 2016
    7
    Can someone tell me if I can run a 2S Lipo 5000mah 30C, or 2S 6000mah 50C on a castles MM2. I see castles reccommends you use 4S. But if I plan to rig this in a 1/10 scale truck can I use a 2S battery?
    Jul 2014
    NAWLINS
    3,952
    Quote Originally Posted by PedeRunner69 View Post
    When doing research on a product iy helps to read the whole thing in it's entirety ......
    From Castle's MMP product page....
    Waterproof : No
    Telemetry Capable : No
    Data Logging : No
    Auxiliary Wire : No
    Minimum Input Voltage : 2S
    Maximum Input Voltage : 6S
    Sensored Capable : Yes
    T/SportMax/Slayer Pro/Bandit
    Stampede/Rustler
    Dec 2016
    7
    Not the MMP, the mamba monster 2, 3800kv motor and esc. It was in my friends e-maxx
  33. #33
    Dec 2016
    7
    Quote Originally Posted by JerrysMaxx View Post
    Waterproof : No
    Data Logging : No
    Auxiliary Wire : No
    I meant the MAmba monster 2 motor and esc. Will those 2S be good enough and by good enough I mean will they have enough juice for when the motor draws or will it be underpowered? or should I get another of the same battery and run in series? For 4S?
  34. #34
    Jul 2014
    NAWLINS
    3,952
    Here is the spec sheet for the MM2. Sorry I miss read.
    http://www.castlecreations.com/esc-s...sc-010-0108-00
    It would work with 2S but I would stick to the higher C rate. IMO that setup is overkill for the 2wd pede. I took my MMP out of mine and stuck it in my Slash.
    Stampede/Rustler
  35. #35
    Dec 2016
    7
    Thanks I know it's overkill. It went in my Pede 4x4. I'd get a MMP but here in Canada it's to wet I need a waterproof esc. I just wanted to make sure that I was getting enough power. Before I continue using it.
  36. #36
    Dec 2016
    7
    I will probably end up getting the 3800kv sidewinder waterproof esc and motor. For now I was just taking advantage of a buddies sitting emaxx haha
  37. #37
    Dec 2016
    7
    I was also wondering what gearing I should run with the stock spur gear. I think it came with a 18T pinion
  38. #38
    Jul 2014
    NAWLINS
    3,952
    With that system I would gear up. Maybe start at 23/86 and check temps then gear from there. I did a lot of looking b4 I got my MMP and had so many stating the MM2 was no more faster than the MMP some stated it was even slower. I saw a video on Youtube of a guy showing this.....IDK but when my buddy GAVE me a brand new MMP well my decision was made. My MMP is certainly faster than the MM2 now
    Stampede/Rustler
  39. #39
    Dec 2016
    7
    Ok will do thanks for your help and time! I'll have to stop by the hobby store tomorrow and see if they have what I need. ����
  40. #40
    South of St Louis
    6,369
    I can still update the software on my 10-year old sidewinder from the Castle website. Outstanding!
    Quote Originally Posted by dragon breath View Post
