Results 1 to 13 of 13
    Dec 2008
    mowing a lawn (MN)
    522
    how to change compression
    my engine has tons of comprssiion and i'm sick of getting scabs every 2 mins. so i tried somthing my friend said and just barely loosend the head.. now theres less compression but will it mess anything up?!?!?!
    pm me with what BRUSHED motor for rusty
    Illinois
    88
    If you add a few more copper gaskets that should lower the compression. You'll have to play around to see how many you want to get the compression where you want it.
    Jan 2008
    Sugar Hill Ga.
    8,397
    Quote Originally Posted by brushedmaxx2
    Ahhh yes. Loosening the head will result in and air leak. The engine will not run correctly and most likely overheat. Not to mention the mess it will make with the fuel leaking.
    Sounds like you're using a pull start. If the engine is tunned properly with no leaks in the fuel and exhaust systems 1 or 2 tugs of the rope is all it should take to start.
    Miami, Florida
    3,859
    Just keep starting it that way...with gloves... a tight engine is better then a loose one. As with everything else
    Jun 2008
    Lost & Found on the intersection of Walk & Don't Walk
    1,614
    Is it flooded? I know a .15 is hard to pull when flooded.
    NOBAMA '08 Welcome to the Greatest Dprsn.
    Nov 2007
    dirty' jersey
    892
    just use a roto start and you wn't have to worry about your hands and loosing the head on that engine and running it will kill that motor fast. be preparde to buy a new motor
    Feb 2008
    Phoenix
    397
    How do you get scabs?
    Dec 2008
    mowing a lawn (MN)
    522
    THATS JUST STARTING IT TWICE
    Dec 2008
    baltimore md
    124
    sorry cant resist
    use your other hand
    Dec 2008
    mowing a lawn (MN)
    522
    lol i tried but i'm right handed i'v tried to just use other parts of my hand.or a glove
    Apr 2008
    Middletown Ohio
    566
    boy i sure do hate the pull start, but it does make things easier like adjusting your motor, weight.. but i switched back after a few days i put my ez start back on lol
    jato armed rusty 3.3
    Feb 2009
    Where the weakest are killed and eaten for the daily survival
    778
    Quote Originally Posted by josef15111
    On 2.5 and higher motors, I agree, but on the .12-.15, It's not that hard.
    Nobama '08 Welcome to the greatest depression.
    Sep 2008
    berwick, PA
    626
    wow ive never had a problem with the pullstart on my 2.5.
    its always started right up...
    usually the first half of a pull is hard because there is no oil on the piston to lube it...
    give it a slow half to full pull and then give her a yank....or 2..lol
    that always helps with my motor
    !!!IF IT AIN'T REVO IT AINT WORTH IT!!!
