Results 1 to 15 of 15
    Dec 2008
    355
    Wink will an 8 cell fit in a slash?
    will an 8-cell battery fit in the tray of a slash? It looks like it will if you take out the foam block and the cells are arranged so
    six cells are in the standard position,
    one on top in standard hump style,
    and one on the end perpendicular to the others.
    Jul 2008
    Michigan
    1,319
    yes i guess that would work
    Yes, I drive an electric converted Nitro Hawk.
    Jan 2009
    229
    it works you can go up to 9 cells with two in the "hump"
    Feb 2009
    Central Ontario, Canada
    1,125
    there's also a hump pack battery hold down for the slash i do believe..although I don't know where you would find it.. tower hobbies perhaps? I'm not sure..I've just heard of it
    Fluttershy is best pony.
    Jan 2009
    229
    I have humps with the factory hold down.
    Jan 2009
    229
    Feb 2009
    here
    392
    you can fit 7 parallel in the tray and then i guess stack as many as your esc and motor will handle on top. just use velcro straps to hold the battery down. it would be heavy though.
    ...true story.
    Jan 2009
    229
    the single humps fit without the straps.... thats all I am trying to say
    Feb 2009
    here
    392
    only if they are unmatched stick packs. if you get the matched parallel packs from promatch or spc then you will need straps.
    ...true story.
    Dec 2008
    rhode island
    475
    Quote Originally Posted by Fox
    That hump is for saddle style
    Dec 2008
    San Diego, CA
    1,860
    An 8 cell will fit the slash but the motor won't last long. I burned up a 15 turn Epic modified on the 2nd run. The XL5 also went from bearly being warm with a 7 cell to getting pretty hot with the 8.
    As far as fit, yes, the promatch will fit, it's the same 8 cell I have.
    Jan 2009
    La Mesa, CA
    65
    Traxxas part #5827X is a higher battery hold down with a taller pin, hold down and block. (20 & 29mm)
    HTH
    Bruce
    Jan 2009
    229
    Quote Originally Posted by bdh11
    HTH
    Bruce
    thats for some huge hard pack lipo right?
    Jan 2009
    La Mesa, CA
    65
    I have no idea! Got one for $3 so...
    Bruce
    Feb 2009
    94
    I run 8 cells nimh and 3s lipo.. holds up fine so far. Not too hot, but the weather here is still cold so that might help.. Runs like a champ for me, but i know the 3s lipo really hurts the lifetime of the stock setup..
    Traxxas Slayer and Slash, Thunder Tiger Silver Fox
