Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 143
  1. #81
    RC Champion PowerToTheMaxx's Avatar
    Sep 2010
    Chicago, IL
    2,338
    How long did you run before you stripped the hex?
    This parrot is NO MORE!!! This is an ex-parrot!!!
  2. #82
    Jan 2008
    Quebec Canada
    531
    Like 20 min but 1 wheel nut came losse and I didn't notice it before the hex was stripped.
    I'll take pics of what I did to fix the rim!
    Here is pics:
    3906 CC 1717 / MMM GA 7075 UE Khead LST2 DIFF
  3. #83
    Sep 2010
    Chicago, IL
    2,338
    Nice, good thinking, how does it work?
  4. #84
    Jan 2008
    Quebec Canada
    531
    Perfect until now.
    But it's not the first time I do that.
    It'll last for long time like as the previous one!
  5. #85
    4
    Do your differentials rotate around the wheel axles or do they fit tight enough in the bulkhead to keep this from happening? It doesn't appear you have anything in place to keep this from happening like the stock differentials.
    Very nice maxx I will be copying some of your concepts. I have successfully mounted the CC 1717-1580KV on the e maxx transmission and am looking to beef up the drive train.
    Thanks,
    Kirk
  6. #86
    May 2006
    DENMARK
    1,401
    Quote Originally Posted by kcjarvis56 View Post
    Thanks,
    Kirk
    You need a collar between the LST diff and the TRX bulkhead
    like this
    or this
    Morten SnoopMaxx
    3906 ROCKSTAR Makita
    c",)
  7. #87
    Jan 2008
    Quebec Canada
    531
    I'm in the same process! But for me, I can't beef anything else. ( want to keep traxxas shaft as it'll hold up with that set-up)
    Show me pics of your monting setup.
    I bought another Gorilla single motor mount ( not receved it yet) and I'll drill it to fit 4mm screwsof the 1717.
    I have a dilemma, as I read in a few forum, 1717 seem to want heavier ride to perform at is best. I may try my 1520 before. With the 1717, I'll have to buy Cen GST wheel, tire and 23mm hex as they are a lot heavier. The 1717 will love it I thing.
    Right now, my maxx weight 12,5 pound with 6s lipo.
    1 thing for sure, the kids will LOVE to be pull around with that futur beast.
    Nice to see ya Snoop!
    Do you have another set of those spacer that you can get rid of?
    Any mod to your since your last post Snoop?
    I bought a charger and power supply used, I was tired to be limitted to 4s 1C charge limit of the ICE charger.
    Its a 550W supply with Dual 17amp rails - Each rail is wired to a separate deans connection.
    Briang's mod iwas done by previous owner to add a slight load to on the 5v rail to stabilize the voltage.
    Now I'll be able to charge my 2 * 3s pack a single 6s ( just need to make balance harness)
    I love when my thead is back to the top by someone else, Keep posting guys!!!!
    I'll show you the mod as they come.
    Fred
  8. #88
    May 2006
    DENMARK
    1,401
    Hey Fred
    My Maxx is still in bits ... (I made a few 775 motor mounts and didn't assemble my Maxx again)
    I'm expecting a 6082 T6 round stock tomorrow so I can start making more of the collars as well as other parts
    I'm also designing a new front collar for the LST diff
    Morten SnoopMaxx
    c",)
  9. #89
    Jan 2008
    Quebec Canada
    531
    Keep me aware of this.
    I may buy a set if they'll be for sale!
    Fred
  10. #90
    4
    Morten - Thanks for the info. I, also would like to buy set of those spacers from you if they are for sale.
    Fred - I will post some picture of the motor mounted tomorrow.
  11. #91
    May 2006
    DENMARK
    1,401
    Fred & KC
    I'll keep that in mind
    I got the 6m allot rod ...If only I could get more free time...Work is getting in the way right now
    Morten SnoopMaxx
    c",)
  12. #92
    4
    Here are the pictures of the CC 1717-1580KV mounted on the emaxx. I put a Velineon next to it for size comparison. Tried to show where I had to take the fins off the motor with a dremel but that does not show up real well. With the stock single motor mount it has very limited gearing. Currently I have 22 pinion and 68 spur. Any combination (spur teeth # + pinion teeth #) with 90 to ~94 teeth 32P will work. Of course the mounting plate hole and the slot had to be drilled and dremeled to 4mm so the motor could be mounted. I not looking for a speed deamon, just something that beats my son's stampede and will not break or overheat every time I take it out. I have the LST2 differnentials, RPM arms (true track), FLM chassis and aluminum bulks, I will be adding. Already have the FLM shock towers and big bore shocks with upgraded springs. Like Fred we spend a lot of time running in the snow.
    Kirk
  13. #93
    Jan 2008
    Quebec Canada
    531
    Nicely done but I doubt the motor plate will hold the weight of the motor when jumping.
    You can put a kind of brace betwen the rear of the motor and frame to prevent exces of flex resulting in a stripping spur since you're on a .8 mod. ( Change that for mod1.)
    Mine will be done with the gorilla single motor mount.
  14. #94
    4
    I received all the parts and completed the mods which included FLM chassis, LST2 diffs, RPM Arms and true track, aluminum bulkheads and LST2 CVD. The drive train seems to be bullet proof. Here are some photos:
    Mock up of the LST2 diffs and CVD
    The RPM true tracks with the 17mm hub
    RPM true track with 15 x 24 x 5 bearing mounted as close to possible to the inside, so the LST2 CVD would work.
    Pictures of the finished product
    Thanks everyone for sharing your ideas, I have shamefully copied the concepts, to build a fun and reliable e maxx.
    Kirk
  15. #95
    Jan 2008
    Quebec Canada
    531
    Very nice but you may want to start your own built tread with that amount of pics.
    BTW I didn't install nine yet. I'll wait the end of winter.
    During this time!!!
    http://s265.photobucket.com/albums/i...t=MVI_1663.mp4
    http://s265.photobucket.com/albums/i...t=MVI_1662.mp4
  16. #96
    Jan 2008
    Quebec Canada
    531
    CC 1717 here we go!!!!
    I install it a week ago all I can say is WOW.
    Gear like this:
    Differential Ratio: 3.3076923076923075
    Transmission Ratio: 1.7222222222222223
    Other Ratio: 1
    Spur Tooth Count: 51
    Pinion Tooth Count: 25
    Total Voltage: 22.20
    Motor KV: 1580
    Tire Diameter (inches): 5.84
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0
    Spur/Pinion Ratio: 2.04 : 1
    Total Ratio: 11.62103 : 1
    Tire Circumference (inches): 18.35 inches (466.01 mm)
    Rollout: 1.58:1
    Total Motor Speed: 35076 RPM
    Vehicle Speed: 52.44 mph (84.24 km/h)
    Effective KV Value: 1580
    KT constant: 0.86 oz-in/A
    Motor Torque: Amperage not specified...
    Final Torque: Amperage not specified...
    Final Power: Amperage not specified...
    I ran a full 6s pack on a beach in hot weather ( 34 celcius) and everything was just warm. I don't expect my medusa 2000kv to take this kind of weather.
    Now I will be able to pull the kids with it this summer!
    Fred
  17. #97
    Jul 2010
    England
    5,777
    I'm amazed you managed to fit the motor, sounds like a setup if the temps are low like that- what kind of runtime did you get?
  18. #98
    Jan 2008
    Quebec Canada
    531
    It was very easy for me, the dificult part was to find a second Gorilla motor mount and enlarge to accept 4mm screw and 25t pinion but plan to enlarge the slot a little more to accept a pinion up to 28t-29t.
    Around 30 min but my lcv is set for 3.4v and with the number of people on the beach I was not able to do wot pass very often.
    I'm glad I didn't sell any of my motor with the motor price growing liks this. ( cost of Neodymium )
    Fred
  19. #99
    Jan 2008
    Quebec Canada
    531
    A little of history. ( Motor and Batt since the beginning)
  20. #100
    Gresham OR
    20
    how much was thouse castle motors?
  21. #101
    Jan 2008
    Quebec Canada
    531
    I bought them for $65 ( 1520 ) and $70 ( 1717) when Castle has their clearance sale.
    Check post 72
  22. #102
    Jan 2008
    Quebec Canada
    531
    Full speed hit with a sidewalk ( 40-45 mph) Didn't BROKE anything but... CC 1717 is heavy.
    It was my baddest crash until now.
    My girlfreind saw the crash and lipo flying and said: I warrenty you it's in 100 peices!!!
    I told her : No, no, it's nothing, the lipo came loose. ( But I was hoping she wasn't right!!!)
    The massive hit result.
    The lipo hit the slipper and trans ( to add to the crash )
    I understand why the chassy bent a little only where the trans is mount!!
    6s lipo was throw 30 feet away. ( 4 big ziptie snap )
    ABSOLUTELY no other dommage done but I don't like strip down my maxx to acces the chassy.
  23. #103
    Jul 2007
    France
    2,286
    Wow I had missed this last crash !
    I bent my chassis too but you widely beat me :
    Did you replace the chassis ?
  24. #104
    May 2010
    Nova Scotia ,Canada
    1,246
    Hey how about some updates on this beast?
  25. #105
    Jan 2008
    Quebec Canada
    531
    enjoy
    I tryed some Baja wheel but no luck
    I broke 2 stub in 5 min
    Need beefy stub for that mod
    1717 on ice!!!
    I ran like that little MORE than an hour, realy, 1 hour!! Very slowly in 1st gear but I'm still amaze.
    Me and my son ( ~ 200lb) on a sled.
    It's not very long but still....awsome!
    Fred
    P.S. The diff are holding perfectly since day 1
  26. #106
    May 2010
    Nova Scotia ,Canada
    1,246
    Why haven't you tried xxl cvds?
    cool vids!
  27. #107
    Jul 2007
    France
    2,286
    COol Is it an ice-cold lake ? Cracking-sound is awesome (but maybe it's just the sound of the sled).
    No fast run ?
  28. #108
    Jan 2008
    Quebec Canada
    531
    Quote Originally Posted by bentrocker View Post
    cool vids!
    Don't have the time for now but mainly cause the truck work VERY well like this!
    And I don't want to reach the diff until I HAVE TOO.
    But I have a set laying around to do the mod.
    With normal tire off corse,
    Poxpox, fast run will be there soon.
    I have an event here with some Baja and a french forum member over Ue, RCM, CentralMaxx, RecoPower: Gilou.
    Do you know him?
    Fred
  29. #109
    Jul 2007
    France
    2,286
    Yep I saw his trucks on his Centralemaxx website a long time ago. He has never posted here I think.
    Pics and vids would be great
  30. #110
    not sure if i am following this right. i already have the traxxas steel drive shafts both center and four corners. i did the lst2 diff and replace the drive 8mm drive cup on the centers and replace the output drive cups with an hpi model that is a little longer. i used the traxxas wheel axles by cutting off the threaded part for the diff. i keep throwing out the right rear drive shaft. am i using the wrong shafts?
    Thanks
  31. #111
    Jan 2008
    Quebec Canada
    531
    I kept the plastic shaft and never got prob!
    I replace them often but they are cheap and I can replace few broke one with 1 new one.
    But I run my MMM CC1717 with 80% of PUNCH CONTROL and still have to be gentle with the trottle
    FRed
  32. #112
    Jan 2008
    Quebec Canada
    531
    Last time I pay attention to the VIEW number, I saw around 6000 view!
    And now, Almost 12000!!! Wow.
    No one told here if there mod are holding well and commenton that mod!!
  33. #113
    Sep 2010
    Chicago, IL
    2,338
    LST diffs are popular now, and this is a great build thread with a lot of cool mods and step by step instructions. Wish I had half your budget though
  34. #114
    maryland
    110
    Does anyone know if they make this exstension kit for a 3905? I would really like that b/c that probably really improves handiling and im trying to make my 3905 into a absolute beast at the track-thanks
  35. #115
    May 2006
    DENMARK
    1,401
    Your parts will ship tomorrow
    Morten SnoopMaxx
    c",)
  36. #116
    Sep 2010
    Chicago, IL
    2,338
    KD makes some extensions I think
  37. #117
    maryland
    110
    That truck is SWEET! I have a 3905 with flm chassis and lots of upgrades but its still not as hot as that truck is! Great work!
    Nitro soup@urc forums-Andrew Nabb on youtube
  38. #118
    Jan 2008
    Quebec Canada
    531
    Nice Snoop!!!
    THANKS a LOT!!!
  39. #119
    May 2006
    DENMARK
    1,401
    Quote Originally Posted by EMaxx_Quebec View Post
    Nice Snoop!!!
    THANKS a LOT!!!
    Look for a white envelope with brown tape and
    F. B.
    Canada
    Written on it
    Oh and just a note.
    They are very tight and if you don't file the housing at the seam
    you can't get them on
    Enjoy
    Morten SnoopMaxx
    c",)
  40. #120
    Jan 2008
    Quebec Canada
    531
    Nice.
    I'll post pics when I'll receve them!!.
    Thanks again Snoop!!!
    Fred
