    Jun 2005
    MN
    223
    Are the 3.3 and 2.5 rear differentials interchangeable?
    easy enough question...
    Nov 2007
    Mass
    2,373
    yes they are.. i have the 3.3 4909 t-maxx and i put 4908 seald diffs in.. the 4910 diffs are the same as the 4909 diffs.
    T-MAXX 3.3 ACNCM BBcHaSI...Jato 3.3..33the Best sb
    Jun 2005
    MN
    223
    Thanks for the quick reply
    13,559
    Hey, if the 4908 diffs fit, I would go with the E-Maxx 3905 diffs as it sounds like they are just a little stronger.
    RC Turnbuckle Jr. troutfisher9's Avatar
    May 2007
    NorCal
    5,286
    They are interchangeable if you are using the stock plastic drive shafts....
    With a purposeful grimace and a terrible sound...
    Sep 2008
    2,759
    Troutfisher is right. They are if you are using the slider shafts. If you are using CVDs or Dogbones at all, they are not. This is because the output shaft where the yoke attaches is a different length. With the stock slider shafts, it doesn't matter as they will slide the difference and you wouldn't even realize there was a difference. But CVDs are a fixed length, so that difference will matter.
    Nov 2007
    Mass
    2,373
    it depends on the company chassis you get. i have a acncm axtended chassis i put the 4908 diffs in and the extended shaft fits fine with plenty left in the cups.
    Apr 2009
    11
    Sorry to jump aboard but I have a question. I have a 2.5, but upgraded to 3.3 axle shafts, knuckles and turn buckles. I am using RDLOGIC CVD 2.5 centers but RDLOGIC 3.3 axle shafts. Does this mean I wont be able to upgrade to a 3.3 diff on the rear? How about the front?
