Thread: Throttle servo
    Jul 2008
    1,067
    Throttle servo
    I just replaced my 5th 2018 because the mounts keep breaking Is anyone else having this issue, if so how have you fixed it short of buying a metal cased servo
    Jan 2009
    Philadelphia
    156
    Yeah i agree the mounts on the casing is pretty weak. I've only replace the casing once though so it really hasn't bother me yet.
    Mar 2009
    CT
    70
    same prob here... in a bind; i have zip tied it back down... it half works, works for the minute i guess.. really sucks when it happens mid-race...
    RC Turnbuckle Jr. RC-Crazy's Avatar
    Apr 2008
    Bellevue, WA.
    3,851
    go for 2055, 2070(if you want stay w/ trx). my choice is Hitec 625MG!
    Slash PE & Ja-two.
    Jul 2006
    United Kingdom
    300
    Ive got the 2055 throttle servo now but had the same problem when i first got my Jato, simple solution, which even works with the 2055 is to put the biggest washers you can fit between the two front screws and the servo to dissipate the pressure more evenly to stop the servo mounts breaking.
    O.S .18TZ Powered Jato
    Simple as.
    Apr 2009
    N.C.
    162
    I did this and it also works really good. Take some rubber servo bushings and place them under each screw to eliminate any impact or vibrations that will break the mounts. Kinda like the groments under the fuel tank screws that eliminate bubbles in the tank. Most hobby shops carry these or you can get them on-line.
    Jato Dragon
