Results 1 to 19 of 19
    Oct 2003
    18
    Is this a new record Temp?
    600 degrees!!!!!!!!!!! I think I may have finally killed the 2.5.
    T-Maxx 4910/2 Slash
    Apr 2009
    77
    you might check your batteries in whatever your using to read temperatures cause that don't sound right.
    Oct 2003
    18
    It is correct. I just checked the temp in my buggy then the tmaxx.
    T-Maxx 4910/2 Slash
    Nov 2007
    Mass
    2,373
    i think the motor would cease first at about 400 degrees..
    T-MAXX 3.3 ACNCM BBcHaSI...Jato 3.3..33the Best sb
    Jan 2008
    Sugar Hill Ga.
    8,397
    Not only is it improbable...It’s impossible.
    RC Turnbuckle Jr. Grand National's Avatar
    May 2009
    Southern Maryland
    3,037
    I have had 600.92
    Haha jk
    Thats extremely high, check everything to avoid any problems!
    Casper - 2001 Dodge Cummins (my baby)
    Jan 2008
    Lugoff, SC
    3,837
    I had over 400 once and I thought that was nuts.
    RIP Bart Hinson
    1992-2009
    May 2009
    Cleveland, OHIO
    1,228
    i ran one of my 3.3's and hit around 475 right when it blew.. so i dont know about it seizing up at 400.. and all motors are the same...one could seize up at 250 the other at 450..
    (by the way, my motor was toast anyways so i keeped on leaning and doing wot passes)
    Miami, Florida
    3,859
    600 sounds impossible in these motors.. it'll start expanding so much it wouldn't run at all.
    Oct 2003
    18
    Well, unless that temp exceeded the range of the meter it is correct. the truck has had issues for awhile. Will run fine then start slowing down in the low end. Today it finally stopped moving forward so I held the throttle wide open until it stopped, checked the temp, and saw 600+ degrees. It was also smoking pretty bad from the heat sink
    T-Maxx 4910/2 Slash
    Jan 2001
    Fresno, CA
    2,020
    i wanna see a pic of this 600* motor did it discolor i wonder what the melting point of the block is ...... never mind i found it melting point of aluminum is 1220*
    3.3 t-maxx, O.S. .18TM t-maxx, HV brushless e-maxx
    Oct 2005
    19,529
    You sure you pointed the temp guage at the glow plug? Not a mis-reading.
    At 300 degrees the fuel starts to boil as soon as it enters the crankcase, at higher temps the nitro has evaporated before even making it into the combustion chamber.
    If it was real 600 degrees I bet it would be a new record. I've never seen anything over 340. and anything I saw going to those types of temps was pretty much done for....
    All Lives Matter
    Apr 2009
    555
    at 600f it berst into flames !!! i doubt it because at 600f the truck would work like a big heat sync , and start moving that heat !!!!!!!!!!!
    Jun 2008
    Kentucky
    1,430
    I had one get over 400 degrees once after that it was toast ruined the pinch on the cylinder.
    Revo Picco 26
    T Maxx3.3
    Jato3.3
    RC10GT
    XXX-NT
    Apr 2007
    401
    What heat gun are you using? I don't know of a single hobby grade infra red that goes that high.
    Sep 2008
    2,759
    I don't know, this doesn't seem right to me either.
    Jul 2008
    1,067
    Way back in the day I had an O.S. 18TM up to 580, and btw the Micro Temp MTPRO goes up to -76* to +932*, so there are definetly hobby infra red guns that go the high.
    Score 1 for 1:1 car
    0 for Jato
    Miami, Florida
    3,859
    Highest i ever had one go was 430.. the HSN was pretty much closed all the way.. if i took my finger of the throttle it would stall... engine lasted about 5 minutes after that doing insane wheelies though... it was worth it, considering im all brushless now
    Oct 2003
    18
    This was using the supplied wire to my volt meter that reads temperature. who the **** knows, but i did see 600 degrees for several seconds. I pulled the motor today and I can easily turn it by hand with only some resistance. Does that confirm a fried motor? My poor max is trashed at the moment. I split the steering servo, my tranny only has one gear, and now my motor is toast.
    T-Maxx 4910/2 Slash
