Results 1 to 20 of 20
    RC Turnbuckle Jr. Grand National's Avatar
    May 2009
    Southern Maryland
    3,037
    Jato 3.3 break in?
    I was just trying to break in my jato and I couldn't get it to hold an idle.
    The truck would start, and if I held the EZ-Start button it would work but once I let go it would shut off.
    The batt isn't fully charged and it's barely charged. Could this be the problem? It starts but just doesn't idle unless the EZ-Start is going on it.
    Casper - 2001 Dodge Cummins (my baby)
    May 2009
    Southern Maryland
    3,037
    (the truck is brand new, never started and driven)
    Sep 2008
    Alvarado, TX
    937
    you may have to warm up your head with a hair drier. if you can give it a bit of throttle and keep it going then go through the break in process, 3.3's can be pains
    sig edited for content
    May 2009
    Southern Maryland
    3,037
    Quote Originally Posted by turborx7gen2
    When I give it throttle I eventually have to give full throttle then she shuts out.
    Think it's the battery problem?
    And how do I do the hair dryer thing?
    Sep 2008
    Alvarado, TX
    937
    whats the temp there? no, the battery does not have to be fully charged but has to have enught to turn the motor over. check your idle gap as well 1mm is what it should be
    Jun 2009
    62
    Just give enought trottle to get going but not to much cuz hes very rich out of the box.
    If it will not work then lean it a little bit.
    RC Turnbuckle Jr. RC-Crazy's Avatar
    Apr 2008
    Bellevue, WA.
    3,851
    check the glow plug, you should not give a full throttle during break in. the engine was set on rich from factory.
    Slash PE & Ja-two.
    Sep 2008
    Alvarado, TX
    937
    i wouldnt lean it out anymore than 1/8 of a turn if you do
    Jun 2009
    62
    Yes
    BUt im sure leaning out is not nesassary.
    I got a jato since 2 days and starting it the first time is quite hard.
    Cuz its rich and ur engine is cold.
    U just have to give that exact amount of throttle to get going.
    May 2009
    Southern Maryland
    3,037
    I checked the gap and it seems normal.
    I tried enrichening it, and it worked some but not enough.
    I did about a 1/2 turn.
    The glow plug is brand new!
    and it does start just doesn't idle, so it's most likely not the glow plug.
    Sep 2008
    Alvarado, TX
    937
    thats why i said to heat it up with a hair drier, you are the one who suggested leaning it out
    May 2009
    Southern Maryland
    3,037
    What will that do?
    Sep 2008
    Alvarado, TX
    937
    well the motor is so fresh that the piston in the sleve is a bit tight, also its cold and never run before. that will help out because the temp will be hotter. also if you richened it by a 1/2 turn than it is going to be even harder to start, you are going to need to lean it through out the break in. also 1/2 a turn is way too much to lean it out being fresh
    May 2009
    Southern Maryland
    3,037
    I set it back to factory.
    Now.
    When I start it, I just put the blow dryer on the cooling head of the truck?
    Down in the glowplug or what?
    Also should I take the plug out?
    Thank you very much!!!
    Sep 2008
    Alvarado, TX
    937
    hit the head from the side, not straight down, also i think this is somewhere in the manual, ill have to look. what do you mean by what setting of the glow plug?
    May 2009
    Southern Maryland
    3,037
    IT WORKED!!!!
    I still have to hit the gas a little from the start but I think that has to do with the engine being new. I broke in my first tank! I accidently let it run out of gas on it's own, will this affect it?
    YAY!
    May 2009
    Southern Maryland
    3,037
    Oh and while breaking in, it did stall 2 times.
    Sep 2008
    Alvarado, TX
    937
    stalling has a good chance of happening when breaking it in and running it fully out of nitro at first is not great but you will be ok. i ran my first 3.3 out of nitro when breaking it in on every break in tank cuz i didnt fully read directions but 2 gallons later it still runs like a champ, but you may burn up a glow plug (but you should always have a few extra on hand)
    May 2009
    Southern Maryland
    3,037
    I successfully did the break in.
    She runs like a champ.
    The idle is still a little off, but it is a matter of leaning it out I think.
    I just took it in to clean the air filter and put on some after run oil. Shes all lubed up right now. I might take her out later again to show off.
    She ran great, thank you very much for all of you help.
    -GN
    Jul 2008
    1,067
    Its more likley an idle screw issue or even more likley an LSN issue
    Score 1 for 1:1 car
    0 for Jato
