Page 1 of 2 12 LastLast
Results 1 to 40 of 45
    Oct 2008
    auburn, wa
    584
    Pictures of how to shim a diff.
    This is a brief description of how to shim your diffs. I'll do my best to give you a step by step description of each picture.
    Here is a picture of the diff. and the shims I use.
    Remove the 4 screws shown in this picture
    Separate the cases
    Remove this gear
    Place shims on the shaft as shown. I usually start with 1 or 2 shims.
    Slide the shims all the way down until they are against the gear.
    Insert the gear back into the housing
    Put the cases back together and insert the 4 screws
    Check for slop by trying to move the shaft on the left in and out. If it feels snug, check for binding by rotating it. If it all feels good, your done. If it feels sloppy, add another shim. You want it to move as little as possible in and out, while still rotating freely.
    Hopefull this post helps those of you with questions on how to shim the diff. I'm not a pro by any means, this is just the method I use.
    Feb 2008
    oakland ca
    1,049
    great pics and explaining! ive never shimmed a diff, but is that the only place that needs shims? i thought i remember reading there was two places to shim.
    www.knoxxgear.com
    Apr 2009
    Ohio
    102
    I noticed that when I fill my diffs with grease they seem a little tighter. Does anyone else fill theres with grease??
    Easy on the throttle, then punch it!
    Feb 2009
    4,902
    You also need to shim the diff side to side, not just pinion depth. Also, you should never shim a dirty diff...always thoroughly wash all grease off before shimming.
    Grease (inside the diff cup) will make the diff seem tighter when you spin it by hand, but it is actually less vicious than diff oil, so it will not perform as well as diff oil.
    Grease on the ring and pinion is fine, since metal gears need lube, but you only need a little, just enough to coat the gears.
    Project: BL Revo Race Quad & BL G-Maxx G3R CF Revo
    Oct 2008
    auburn, wa
    584
    Yes you can also shim the output shafts of the diff, but that very rarely needs to be shimmed. The input is usually the part that wears first and starts slipping.
    Feb 2009
    4,902
    The ring is harder than the pinion, and the diff moving side to side is what wears the pinion. Pinion depth should only be shimmed AFTER you have the diff itself shimmed side to side. If you can move the diff side to side without the pinion in, it needs to be shimmed.
    Oct 2008
    auburn, wa
    584
    Hmm. Every time I have had a clicking diff, the process shown above has eliminated the problem. From my experiences the mesh between the ring and pinion loosens up, which is why I shim it. I have never had a problem with the mesh on the internal diff. gears.
    May 2009
    106
    This may be a stupid question but why shim?
    Dec 2008
    San Diego, CA
    1,860
    And where do you get these shims from?
    Oct 2008
    auburn, wa
    584
    Quote Originally Posted by michindi
    after a while the gears begin to wear and will start slipping. You can shim them to stop the slipping and get more life out of them.
    Oct 2008
    auburn, wa
    584
    Quote Originally Posted by 2IS
    I get shims from my lhs. They are just 6mm bearing shims.
    Sep 2006
    Good, green, Oregon!
    2,220
    I got the same shims as in the picture from my LHS. 6mm shims.
    One thing that I have found with the diffs that makes a big difference is to not tighten the out case to much. It really starts to bind the action quite a bit. There is a fine line between just tight enough and too tight. WIth the outer case, you aren't really needing to keep any liquids in like the inner case. The grease is sticky enough to stay on the ring gear pretty well.
    Eat my road grit, liver lips! -Clark W. Griswold
    Feb 2009
    4,902
    Quote Originally Posted by yzf128r
    I am not talking about shimming the internal spider gears, I am talking about shimming the output shafts, to stop the whole diff from moving side to side in the diff case.
    Mar 2005
    ◄Incognito►
    1,580
    (√) Zer0 tall-er-ance 4 stu-pid-it-deeeeee.
    Feb 2008
    Texas
    1,121
    thanks, great how to!
    I was anti-obama before it was cool!
    Feb 2009
    4,902
    [Here] is the proper way to shim your diffs...
    84
    When your diff starts clicking what is the best way to find out if it's front or rear diff? Please be as detailed as possible.
    Western Kentucky
    792
    Hold your truck planted to the ground watch to see if its the rear or front tires that skip a beat
    ERBE,Losi 8ight,Slash 4X4
    W Monroe, Louisiana
    2,001
    For me clicking on hard acceleration is rear... And clicking on hard braking is the front.
    Its All relative to your perspective.
    84
    Tks for input guys I'm going to give those recommendations a try and see if I can figure out where mine is coming from.. sounds like it's on the acceleration, will know more tomorrow..
    104
    i'm sure saving this post !!! great stuff guys
    May 2013
    5
    I have had my E-Revo since 3 April and have had to change out both diffs already. I know most will advise me to adjust the slipper and/or use 4S versus the 6S I currently run. How about this, Traxxas should build an RC that can handle the motor and ESC. I may be fairly new to this hobby but I know a crappy product when I buy one. Chevy doesn't tell my not to stomp the gas on my Vett because it will break stuff. If this were a full sized car, it would have been recalled. The E-Revo needs to be fixed! I can't believe Traxxas is allowing their customers to suffer like this. I am VERY disappointed in them. How is it that LOSI's diff can hold up and Traxxas' cannot? Traxxas reminds me of the Gateway computer company of the late 90s. They were an up and coming company, neck and neck with Dell but lost their loyal customer base due to distribution of inferior products and poor response to customer feedback. Traxxas take note; a bad reputation is hard to recover from. PLEASE FIX THIS PROBLEM ASAP!
    The Netherlands
    854
    Very simple, actually.. The losi diff is made for a car that weighs 13 pounds without batteries and gas. The revo weighs in at 9 pounds without batteries and 10.9 with. Thats a huge difference for the diffs to handle.
    That and 6S, 6S is just a lot of power, on any RC. If it is not the diffs that break, something else will break.
    It's almost impossible for traxxas to get better diffs in the e-revo without redesigning a lot. A possible solution for you might be shimming your diffs, something that is not possible in the factory because it different for every diff, but it will improve durability. Another solution is to get a castle link (which should be in the box...) and adjust your Punch control to 30-40% or so.
    But yeah, they could have gone for 1/8 diffs when they designed this car, but i guess the didn't think about that when they made the Revo (not the E-Revo). Almost everything on this car is 1/10, except for the diffs.
    May 2013
    5
    WesleyK, that's all good info, however the bottom line for me is; The Castle Mamba can handle 6S and if they are going to put that setup in the car, it should be able to handle it's full power. My Rustler's motor can handle a 3S and I run it with a 3S often. The Rustler can handle it. I understand normal wear and tear but the e-revo is a flawed product. For a $1K car it should work much better than it does. I still believe they need to fix the problem. They have my money and I have a flawed truck. If this is common place in this hobby and acceptable, I guess I'll have to find a new hobby. I love the RCs but RTR should be RTR. The Slash is a great truck with a ton of hop ups. They need to fix the E-Revo with hop ups. But I guess I'm the exception. Seems everyone just accepts what they get and are willing to try and fix the problem or use a portion 30-40% of what they paid for. If I were abusing the thing, by towing my kid in his wagon or doing tug of wars, I'd blame noone, but all I do is drive on tracks, track like conditions, parks and dirt. I'd don't think it's fair that in just a month I've had to replace two diffs . I love the truck when it's running, but mostly it seems to sit on my work bench in peices .
    The Netherlands
    854
    I have my revo for almost 6 months now, both 4s and 6s runs and i have just rebuild the front diff today. Starts to show some wear but its still fine. Looks like some of us have luck with the diffs and others have not.
    I will agree that if a product is ready to run, and comes with 6S lipos and advertising it should be able to handle 6s. The stock revo isnt, you totally right on that. But punch control is a great way to save the diffs, i barely notice the setting but my diffs are still in good shape as i wrote before. It only helps with putting the power down, like a slipper clutch but electronic. You should try it.
    May 2013
    5
    WesleyK,
    I apprciate your advise. In lue of a better alternative (like a Traxxas fix) I will try the punch control option. Thanks for your time and recommendations.
    Feb 2008
    Fl
    3,062
    Pushing the limits of any rc will cause parts to wear and break faster that is the truth of this hobby no matter the manufacturer. A rustler/pede/slash/bandit diff will break just as easily pushing the limits on 3s as a revo does. I have worn out my share of diffs in rustlers and revos. Point is if it moves it will eventually wear out, if you do your best to take it easy on those parts that are known to have problems they will last considerably longer.
    Don’t handicap children by making life easy
    152
    Quote Originally Posted by bip View Post
    Love it!! Completely agree! We pay for a product that doesn't deliver and nothing happens about it.
    May 2013
    5
    Quote Originally Posted by rjm2519 View Post
    rjm2519,
    Everyone is entitled to an opinion and I respect yours, however, I cannot not subscribe to it. I would wager that I can find 20 posts/articles related to E-Revo diff problems for every one that you can find related to a Rustler and Bandit diff combined. My rustler diff has never failed running 3S nor has my buddy's bandit; so believe what you will but you'll have to present a much more compelling argument if you want to sway my opinion.
    Oct 2013
    Long island N.Y
    140
    Take your vett and do hole shots every day for 2 hrs and see how your clutch and rear end is holding up. Then when it brakes go to Chevy and complain they will laugh at you. I race 1/4 mile cars now for 13 years. I have lost 15k engines in one pass. You need to pay to play. People need to step back and think really what these little Rc cars and trucks are doing. The amount of stress we put on them is crazy. I dont think you can jump your ford f350 all day at 30-50 mph and drive it home in one piece. We just need to realize that pretty much rtr means giving you a good platform to start.
    Sep 2010
    middle o nowhere Ill-inois
    791
    ^^^^+1
    People complain about the stock tires too. I am guessing Traxxas knows they slip - and that saves parts wear.
    These trucks take a huge beating even under mild use compared to their 1:1 counterparts. I agree the claims on packaging are inflated IMO and that's a little lame. But how many car commercials show the driver standing on it curve to curve and a disclaimer is on the bottom of the screen the whole time lol. The E Revo's competitors make plenty of speed claims too I see js.
    The competition has diff troubles/need to shim as well from what I see.
    Summit, ERBE X2, 4pdes, 2pdes, etc lol
    Nov 2013
    37
    I'm having a hard time finding all the needed shims to complete this guide. It's from a couple years ago. Anyone have current links to the parts I can get in one place?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    The Netherlands
    854
    Search for 3R racing shims or Calandra shims on ebay. Both have them in 6mm 8mm and 10mm
    Apr 2013
    778
    Im in the middle of doing my own shimming guide, I will post a link here when done.
    I also use the 3racing shims, as their shim packs come with different thicknesses of each size.
    To SUMMIT up, its my coolest RC.
    RC Champion NFS's Avatar
    Aug 2013
    2,097
    I'm not the author of the diagram it was made from another forum member. Place shims (6mm, 8mm shims) between the differential and the bearing, the purpose is to bring closer the diff ring, and the pinion, also place shims on the pinion itself. Reassembly the diff and the case and check for binding.
    Oct 2010
    NJ
    868
    Like Wesley said, all available on ebay.
    Calandra 6, 8, 10mm shims - p/n: 4736, 4738, 4740 respectively
    Quote Originally Posted by StaticBalls View Post
    Nov 2013
    37
    You guys are awesome! Been getting confused trying to get the right ones and was worried about spending money on the wrong ones. Will order today!
    Apr 2013
    778
    I prefer the 3racing shims for the assortment of thickness` and the LEM O-rings last forever
    Oct 2010
    NJ
    868
    ^^ Various thickness shims are definitely nice to have. I also have Kyosho 10mm shims (KYO96647) that come in 2 thicknesses.
    Apr 2013
    778
    I have finished my diff shimming guide.
    http://traxxas.com/forums/showthread...Shimming-Guide
