Results 1 to 14 of 14
    Jun 2009
    Charlotte, NC
    67
    Cleaning & Maintenance
    How are you guys cleaning your trucks? Would it be okay just spraying it down with the hose with the electronics still installed? If I did spray it down with the hose, what would I need to re-lube to keep everything smooth? Is it possible to get sand/dust into your shocks?
    Jun 2009
    Southern New Hampshire
    349
    I have been using a hose on a gentle setting for a while and it seems to be working well. I only do so right after I run it though, when the dirt is still wet and ready to come off easily. I then bring the truck inside and use a hair dryer for a while as I get as much of the water off the truck as possible. Even with that though, I am still getting a tiny bit of rust on the balls that hold up the wheel axle supports. A thin coating of WD-40 is probably a good idea. I have not had any problems with my drivetrain however, it still is running really smoothly, better than any other drivetrain I have owned in my other trucks. I would just recommend you take off the spur gear cover every so often and clean out you pinion and spur gears.
    Oh, and by the way, you should not be getting sand in the shocks. If sand can get in, then the shock oil is probably long gone and the shocks need to be rebuilt anyway.
    Hope that helps.
    HPI Savage LOSI Mini/MicroT, MRC Traxxas Revo VXL
    Jun 2009
    Western australia
    514
    Air compresser... Hosing you truck down after very run will eventually rust it away.
    GARAGE
    e-revo, ME-revo, micro-t, slash, DX3S
    Jun 2009
    72
    Not if you hit it with WD40
    HPI E-Firestorm
    1/16 VXL Slash
    V3 Bonzer
    Jun 2009
    110
    WD40 will ruin the plastics after a while. Any rubber will over time be eaten away. Just air compress it.
    Jun 2009
    90
    i use the air compressor
    Jun 2009
    72
    I've never seen wd40 ruin plastic.....
    HPI E-Firestorm
    1/16 VXL Slash
    V3 Bonzer
    Jun 2009
    72
    myself i hit it with the garden hose then the air compressor...looks like new and no rust.
    HPI E-Firestorm
    1/16 VXL Slash
    V3 Bonzer
    Jun 2009
    72
    Took a look at the wd40 website..alot of good info,Qoute below
    What surfaces or materials are OK to use WD-40 on?
    WD-40 can be used on just about everything. It is safe for metal, rubber, wood and plastic. WD-40 can be applied to painted metal surfaces without harming the paint....
    HPI E-Firestorm
    1/16 VXL Slash
    V3 Bonzer
    May 2009
    162
    I use a little windex or simple green and then rise it off with bottles of water then hit it with the air compressor till it is completely dry.
    E-Maxx Wicked Fun
    Mini E-Revo Freaking AWESOME!
    Jul 2009
    18
    For those who uses air compressors, if you have drived in sand you will blow sand into the ball bearings.
    Traxxas Stampede XL-1
    E-Revo 1/16.
    Sep 2008
    Pittsburgh
    852
    I know for a fact WD 40 is your friend... no probs with it....
    I just Simple green her if its bad.. compressor, then a light squirt of WD 40 then blow her off again....
    looks like new!!!
    Its how I do the Summit too...
    Three Summits
    Jun 2005
    New Orleans area
    1,188
    WD 40 will also help to keep future dirt from sticking on bad.
    HARDCORR RACING
    Jun 2009
    Charlotte, NC
    67
    I appreciate all the help guys. Should be able to get her clean between all the advice you guys gave.
