Results 1 to 20 of 20
    Apr 2003
    , IN
    971
    Those who race stock class
    what are some good mods to or even allowed, i'm building a race truck
    Race Rustler 18/84
    http://tinyurl.com/5u8ave
    Feb 2009
    Sacramento
    1,861
    stock class is just stock
    gearing might be you biggest advantage
    Feb 2008
    BC
    701
    Battery performance can play a major roll in spec racing so you'd be wise to buy a decent one.
    Vehicle(s): None
    Owned:Rustler,Slash,E-Maxx
    Dec 2008
    Florida
    1,064
    Make shur your bearings are lubed, trans greased, brushings oiled and motor clean, and tune your suspension.
    I have monkeys dancing in my pants!!!
    Dec 2008
    Florida
    1,064
    oops, double post. ohh sure not shur.
    Aug 2008
    412
    Ya can't make it a race truck in a box stock class. (sorry i had to post it)
    Built Ford tuff!
    Apr 2003
    , IN
    971
    im buying all parts and building it, like which bearings with least rolling resistance? Can i lock the diff? can i use rpm bearing carriers, no stock steering servo etc
    Race Rustler 18/84
    Apr 2009
    Sask. Canada
    134
    First thing to replace is the stock pinion gear. They are very soft metal and wear quickly.
    The pinion becomes saw tooth shaped and sharp and will eat the spur gear when if you use reverse too much.
    Feb 2008
    BC
    701
    Quote Originally Posted by condor414
    What type of pinion would you recommend then? I have had no problems with the stock pinion being soft. You shouldn't have any problems if your gear mesh is set correctly in the first place.
    Vehicle(s): None
    Mar 2009
    San jose, California :D
    4,680
    My stock pinion did well for about a month (Untill i wanted to change the gearing). I now use losi pinions, and theyve been great for me.
    Oh yea, about the bearings. Teflon and ceramic bearings will provide much less resistance, but i dont think they will last as long as the rubber sealed stock bearings.
    EMBE/ Savage X
    x2 BL slash
    Ultra lx1e
    Apr 2009
    2SON AZ
    190
    +1 on the Losi pinions!
    Jammin' Nitro Truggy 1/8
    Slash 1/10
    Slash 1/16
    Apr 2009
    Sask. Canada
    134
    I'm running Robinson pinions now on all 3 of our Slash's.
    I have never chewed up a spur myself with the stock pinion. But after my son went through 3 spurs I found the problem was worn pinion and his more frequent use of reverse. Both trucks had about the same runtime on them and both pinions were hooked badly and quite sharp on the back side of the teeth.
    Feb 2008
    BC
    701
    How are you sure that it was reverse that caused it?
    Vehicle(s): None
    Aug 2007
    So Cal
    21,511
    There is a lot of speed to be rung out of a bone stock truck but it is not the kind of thing you are going to learn on a forum. You need to spend lots of time and effort toying with different ideas and gain lots of experience in setting up your truck. Things like perfectly balanced tires, dialed in front end adjustments, perfectly smooth running bearings, polished gear trains, balanced drive lines, and knowing where and how to save weight are just some of the things experienced and winning racers use to make their trucks faster than every one else.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Apr 2009
    Cleveland Texas
    6
    Battery type???
    I have recently purchased a Slash and plan to start racing at local track, I also bought a 8.4v 5000 Nimh battery. Truck runs great for stock, but could I get more out of it with a LIPO pack?
    James Dixon
    Sep 2008
    2,121
    not as much top speed but more power but you need to see if you track allow lipo or not
    Race-bred SSC 4x4
    Durango DEX410
    Feb 2008
    BC
    701
    If your track allows it I would recommend getting lipo they will greatly improve acceleration which will make it quite a bit easier to clear jumps. Also they won't take the top end down much. The lipo is lighter and will provide a better balanced vehicle
    Vehicle(s): None
    Jan 2009
    Pa.
    185
    A decent lipo will be your best upgrade in the stock class. It only cheatin if they catch you.
    Feb 2005
    N 37 33* W122 3*
    200
    shock oil...
    it's like nite and day...
    leo d.
    May 2009
    World's Largest Archipelago
    1,173
    Also mantain and properly run-in your stock motor...if you have some titans around, dyno them to see which has the most output..that's the one you should use to race. Spray some motor cleaner, lube all the brass bushings using light bearing oil..and add some comm drop prior to race.
    Myth busted: Blitz is not faster on the track.
