Results 1 to 17 of 17
    Jan 2009
    255
    Diff Problem Help
    Here is the problem. It seems that my car is running at half speed. I have the esc programed for sport mode. With both rear wheels turning at full throttle while the car is raised off the ground they only seem to be going half speed . If I hold on wheel to keep it from turning the other wheel then turns at full speed but then again when I let both wheels turn they drop to half speed. Any Ideas?
    If you bought it a Big Truck brought it
    Jul 2009
    11
    Your car is messed up dude. You shud get new one. Sounds like it is broke.
    Jan 2009
    255
    Wow! Dude that was some really good advice. Gee Thanks
    Jul 2009
    11
    You should fix it so it works good for you. LOL
    May 2009
    392
    Are you sure that the ESC isn't in training mode?
    I would do a re-program of the ESC just to make sure.
    I have the VXL in mine, and it's plenty fast.. I just tried what you are saying on mine, and it does the same thing.
    Basically, the reason it seems the other tire is going faster is because all of the power is directed to it instead of being spread out through the drive train.
    E-Maxx 3905 and 3906. :D
    Jan 2009
    255
    I know it is in sport mode I rechecked it. Just seems it should be faster. When both wheels spin the tires wont hardly ballon at all but when I hold one or the other they balloon lie they should. Just for comparison I am just a little faster then a non vxl slash on a 8 cell nimh. I run 2s Lipo with vxl brushless. Stock gears
    RC Turnbuckle Jr. Carbonrevo33's Avatar
    Jul 2008
    In a box on Hwy. 64 bashin' with Bradley Youngskins!
    3,979
    Any resistance along the drivetrain?
    Jan 2009
    255
    Quote Originally Posted by Carbonrevo33
    None that I can tell. I my just be getting old and senile. PM sent to ya
    Jul 2008
    3,979
    hmm Battery freshly charged?
    Jan 2009
    255
    I tried all 3 of my lipos with the same result. Ling427ttvette could be correct.
    Jul 2008
    3,979
    yea. That could be true. Sounds right.
    Jan 2009
    115
    the diff is working correctly, something between esc and motor is wrong, check, double check, then triple check 1) programing 2) throttle settings on radio 3) motor connections.
    then report back.
    Jan 2009
    255
    Both rear wheels roll without any resistance. When I turn one wheel by hand the other wheel turns in the oposit direction like it should. I ajusted the slipper clutch all the way in for testing purposes. Spur gear and pinion are at proper mesh. I re programed the ESC and set to sport mode twice just to make sure.
    Jan 2009
    115
    are you using the OE included Radio?
    Jan 2009
    255
    Quote Originally Posted by CeeBlock
    I get the same results with the traxxas TQ and my Futaba 3PM
    Nov 2007
    Sin City, USA
    2,517
    gear it up. the VXL motor is only 3500kv, on a 2s lipo (fully charged @ 8.4v) it can only run at about 30000 rpm... which makes it about the equal of a 15-17t brushed.. its not gonna be very fast... you have got to gear it up if you are wanting to see any real speed. or go up to 3s lipo... the VXL just int all that fast on that gearing and only running the low voltage.. sad, but true.
    Slash 2wd w/ Novak
    Rusty w/ Castle
    Jan 2009
    255
    I could just be trying to compare it to some of my nitro speeds. I now that on 2s it can't hold a candle to my jato which is a beast or my RS4 EVO which is even faster. I will have to get a 3s and gear up to a 23T Pinion or put my Sidewinder and mamba 5700 in it. Thanks guys for the help. I got to go take the kid to the movies.
