Results 1 to 21 of 21
    Jun 2009
    Charlotte, NC
    67
    Bearing Size/Quantity
    Does anyone know how many of each different size bearing is needed. The parts list provided with the kit tells you the size of the bearings that are in the kit, but not how many of each are needed. Boca doesn't make a bearing kit for the e-revo yet so I'm trying to piece together my own. I'd appreciate the help.
    Aug 2007
    Charlotte, NC
    184
    It really depends on what you want to replace with bearings. if you just want to do the rockers, you'll need those bearings, but if you want to do the entire truck, there would be significantly more. the easiest way to find out would be to go through the EXPLODED VIEWS writing down how many of each plastic bushing you see (write down the quantity and the part number). once you've finished, go to the PARTS LIST and find the size of each bushing you have written down. now you have your list.
    Jun 2009
    Charlotte, NC
    67
    Quote Originally Posted by RokeyLounge
    I'm working on going through the parts list now. I'm only replacing the drive bearings, I don't mind the bushing in the steering components. The stock bearing seals failed, which is why I'm replacing the bearings.
    Jul 2008
    Ontario,Canada eh!
    1,166
    ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
    RC RUNS IN MY BLOOD!
    R
    E
    V
    O
    Aug 2007
    Charlotte, NC
    184
    Quote Originally Posted by -J-
    Oh, gotcha. Hate to hear of such problems, but yea, in the future, referring to the drawings and parts list are the easiest way to figure these things out usually. Personally, I have every Exploded View and Parts list saved to my computer for just such the case that I decide to replace a part, or do a mod. I feel it's rather faster than asking the question and then waiting for an answer. Besides, why ask someone else if the information is as easy to get as what can be found in Traxxas' documentation.
    Jun 2009
    Charlotte, NC
    67
    I'm all for doing it yourself, just didn't want to have to slave away for a half hour if someone already had the info I was looking for.
    Nov 2009
    11
    My count, including plastic bushings is ;
    15 - 4 x 8 - tranny included
    8 - 4 x 7
    4 - 8 x 12
    2 - 5 x 8
    Can someone confirm this?
    RC Champion Core's Avatar
    Aug 2009
    Jersey
    1,152
    there's 2 kits available at thetoyz..
    one full kit with 33pcs for 29 dollars
    one wheel bearing kit with 8 pcs for 9 bucks
    "slaving away for half an hour" ... .. seriously ?
    and btw, i won't confirm it. i'm not going to waste my time doing a bearing count if the op can't do it himself.
    /end 2 bits
    Mar 2009
    Escondido
    324
    Quote Originally Posted by kybowtye
    8 - 4 x 7
    4 - 8 x 12
    2 - 5 x 8
    8-8x12
    everything else is correct
    Nov 2009
    11
    Where did I miss the other 4?
    Aug 2009
    Jersey
    1,152
    bulks or carriers
    Nov 2009
    11
    I see...2 on each diff.
    Jan 2010
    Alabama
    859
    Does anyone know the other dimensions of the bearing
    For Example
    4x8
    ID=4mm
    OD=8mm
    Width=?
    I am trying to source the bearings to save a little money. (Or perhaps buy better quality bearings)
    I will post my findings after I do the shopping..
    Thanks
    Edit: I found some of the info I was looking for
    4x7x2.5
    5x8x2.5
    Still needed:
    4x8x"X"
    8x12x"X"
    Jan 2010
    Alabama
    859
    Anyone try the ceramic bearings that tower has listed?
    Click Here to See
    Jun 2009
    Canada
    486
    Quote Originally Posted by Krispy
    Click Here to See
    i saw that, but seriously $90 for 31 bearings? that's $3 each, seems quite a bit excessive to me.
    Jan 2010
    Alabama
    859
    Quote Originally Posted by ThacoVXL
    I talked to the customer support and they informed me that it was a 37? piece kit.
    If you price out ceramic bearings it is actually quite reasonable.
    I just question the utility of such a thing... I held some full ceramic bearings that were made for an F1 application. It wasw simply the most impressive thing I have ever seen mechanically. I started the spinning of the bearing and they continued spinning for what seemed like ages...
    With the $ that I am sinking into my MERV I figure why not....
    I don't know that I will purchase the kit until I know a bit more about the construction of the bearings. I bet it is just a steel race with ceramic balls, which isn't a " true " ceramic bearing setup.
    Aug 2009
    Jersey
    1,152
    boca yellows are about $5.00 each.. oranges are around 15.
    Jan 2010
    Alabama
    859
    Final sizes from searching/assuming
    4x8x3------------------------15-----(19?)
    4x7x2.5----------------------08
    8x12x3.5---------------------08
    5x8x2.5---------------------- 02
    If anyone wants to confirm it would be helpful....
    Jan 2010
    Alabama
    859
    Any clue where this guy could be coming up with 4 extra bearings?
    Jun 2009
    Canada
    486
    "37 piece kit" probably includes the box they come in, and maybe some usless tool.
    Jan 2010
    virginia
    410
    ive heard good things about ceramic nitride bearings,when my merv gets delivered i will be converting
    summit, vxl merv,65mph club
    Oh No I Use Acronyms
