Results 1 to 37 of 37
Thread: Reducing Temps
    Apr 2009
    204
    Reducing Temps
    After a min of running temps of my motor and esc are getting a bit hot.You can touch it with a finger but getting pretty hot.
    -2 Promatch Racing 1600 packs
    -Series Connector
    -Mini Quake Heatsink for motor
    Any ideas on what can help or what I should do?
    Thanx
    Jun 2009
    804
    is there a gap between the heatsink and motor?
    keep your mouth closed and let your eyes listen
    Jul 2009
    742
    Well, you really gotta know what the actual temps are, you really won't want to keep your finger on it after about 100*F, it will get hot, it's "supposed to", it just depends on how hot. But with the 2 packs in series, it's no wonder, you're pushing the powertrain to its max with those. Only thing really would be a heatsink on the motor and maybe a fan on the ESC, and maybe a gearin change. You using the pinion they say to use when in series, the optional one that came with it?
    1/16 Revo
    X-60
    X-6
    Jul 2008
    Chicago
    5,114
    Quote Originally Posted by ////AMG
    -Series Connector
    Thanx
    I would not judge the temp with a finger. Get a temp guage. The ESC will go into thermal protection at 160-165 degrees. Meat cooks at 130-140
    Keep flex'in those forum keyboard muscles.
    Jun 2009
    804
    my esc always goes into thermal protection do to I do tons of donuts
    Jul 2009
    742
    Does the motor also have a way of thermaling too? Or at least a way for the ESC to know the temp or whatever, some way for the thing to stop itself if the motor is going to overheat too?
    1/16 Revo
    X-60
    X-6
    Jun 2009
    804
    Quote Originally Posted by xtraman122
    nope...................
    Apr 2009
    204
    Whats the cheapest temp gun i can buy?
    May 2009
    153
    Duratrax one for $25-ish at Tower I think ?
    Jul 2009
    742
    Here's all the cheapest ones I could find.
    - Cen Tech, looks IDENTICAL to the DTX one
    - Duratrax
    - HPI
    - Axial
    1/16 Revo
    X-60
    X-6
    Jan 2009
    New Jersey
    1,041
    touching your finger to it can tell nothing. i can touch my motor when its hot but i could never give a degree. get a small on board that you can look while running. i bought the little lime green venom micro temp gauge on ebay for like $18 or something. hot to your finger can be around 130 which is about normal for it to run (for me anyway) and hot to your motor and esc would be like 170-180, which would give you a burn right away. all that is IMO.
    what was that? what was what..oh that. thats mine.
    May 2007
    318
    with burshless motors.. heat guns are a must. and besides my heat sink i did a hole in the window on the motor/esc side and it helped even more than the heat sink.
    "You must first climb, to be at the top"
    Dec 2008
    Mission, TX
    166
    My ESC would go until into thermal shutdown stage 1 all the time with 2 batteries in series. Even after I cut holes on the body. But then I added a blowing fan, it hasn't shut down on me since. The ESC stays at 105 degrees. I moved the servo to the other side so I could zip tie the fan.
    I'm thinking just adding a fan to the ESC heatsink is the best idea.
    I've found a fan like that laying around that looks like this, I'm going to try that tomorrow and see what happens.
    Here's the link http://www.newegg.com/Product/Produc...82E16835119098
    Jan 2009
    New Jersey
    1,041
    +1 on cutting a hole Pede, i cut out where the entire windshield was supposed to be and temps before after two packs were about 150 and after the hole are around 130-135
    Apr 2008
    Altus, Oklahoma
    332
    wow thats a huge fan! i bet it keeps things nice and cool.
    Got Li-Po?
    Apr 2009
    204
    Quote Originally Posted by mx2004
    Where did you get the fan in the pic?
    Dec 2008
    Mission, TX
    166
    I got it from a computer case. It's made my Yate Loon Electronics, PN: d50bm-12b. I did a Google search but that part number on their website shows another fan. Here's one like it though...
    http://www.newark.com/nmb/bm4515-04w...wer/dp/68K1095
    Apr 2009
    204
    How did you hook it up whats it running from?
    Apr 2009
    204
    Quote Originally Posted by zrau17
    This?
    http://www.greathobbies.com/producti...rod_id=VEN0601
    How are these are they common sense?
    Apr 2009
    204
    Dec 2008
    Mission, TX
    166
    Just hooked it up to the back of the ESC battery connector, worked fine, turns on as soon as I plug in the battery. You can also pick up a cable at you lhs that connects to one of your Rx's channel and hook it up that way... someone here told me it outputs 6 volts.
    RC Qualifier JatoTheRipper's Avatar
    Sep 2007
    PA
    773
    - Duratrax
    - HPI
    - Axial
    Thanks for the links!
    The CEN one looks better than the Duratrax because it seems to have more features. I wonder if it's as accurate and reliable, though.
    Jun 2009
    Western australia
    514
    Quote Originally Posted by JatoTheRipper
    buy the one off hobby city
    http://www.*********.com/*********/s...idProduct=8297
    very cheap and very good.
    GARAGE
    e-revo, ME-revo, micro-t, slash, DX3S
    Apr 2009
    204
    Quote Originally Posted by concreat
    Shipping kills the deal
    Jul 2009
    742
    I never thought of checking there, I'll have to pick one up on my next order.
    1/16 Revo
    X-60
    X-6
    May 2009
    N/A
    297
    Just gear the truck to run at a decent temperature, your trying to put a bandaid on on when the gearing really need to be changed. Add a heatsink to the motor, it will work better then the fan and buy a temp gun, they are $40.00 for a O'Donnell which is cheaper then your motor or ESC. The max temp on that motor is 200 degrees, I put a heatsink on mine and I am running a 45 spur with a 27 pinion and she fast enough to have fun and keeps the temps in check.
    ERBE+TEKIN RX8+MAXAMPS=TO TOUGH TO TAME!!!!
    Jul 2009
    742
    Don't brushless motors actually get hotter when they get geared down? I was wondering also why they say to use a smaller pinion for the speed runs with 2 packs in series, I figured with more power you'd want a bigger pinion, or does it just put too much of a load on the esc?
    1/16 Revo
    X-60
    X-6
    Mar 2009
    654
    Do these brushless motors run cooler during the winter?If so I will just wait to try series.
    ERBE
    Jul 2009
    SOUTH OF THE MASON DIXON LINE
    145
    PICK UP TRUCK,A BLONDE & A BASSBOAT & 80%.
    Jul 2009
    27
    are you guys having huge heat issues running 3s lipos in parallel on stock gearing?
    Will cutting out the front window help this or should I regear?
    I have hit thermal shutdown twice in series with the stock batteries and I'm wondering if the same thing is gonna happen with the lipos
    Jul 2009
    742
    In series you're supposed to go to the smaller pinion to put less of a load(current draw) on the ESC. I would probably do the same with 3S, but I see no point anyways, the thing is already stupid fast on 2S.
    1/16 Revo
    X-60
    X-6
    Jul 2009
    185
    I picked up that Centech temp gun at Harbor freight, there is a couple stores in the chicago burbs.
    It was $9.99 !
  33. #33
    Dec 2008
    Mission, TX
    166
    Quote Originally Posted by Justanotherguy
    It was $9.99 !
    That's a good deal! I probably have the same one (same brand and bought it from Harbor Freight) but I paid $40 for it i think.
  34. #34
    Jul 2009
    742
    There's a Harbor Freight 20 minutes from me, I'll have to go look.
    1/16 Revo
    X-60
    X-6
  35. #35
    Aug 2006
    86
    I added a fan and cut out the windsheild and added screen to it to keep out the big stuff.
    3.3 Revo,T-Maxx ,1/16 E-Revo,2.5 4Tec
  36. #36
    Jul 2009
    Miami, Fl.
    307
    I had my first thermal shut down today. I was doing speed runs on grass. (not smart) The wheels kept going faster and faster and the truck,,,not so fast. I was chasing my son and we had a blast. I did learn not to do this anymore and I am just giving you all fair warning to. BAD IDEA. After a few minutes cooling down it was ready to run again. All on 3s 1550 *****s. As for a temp gun, I use my craftsman from my garage.
    ________________________
    3.3 Revo 1/16 Revo VXL
    & soon 1/16 Slash VXL
  37. #37
    Feb 2008
    sterling hts MICHIGAN!
    2,034
    cut out the roof scope to get some air in there
    if you want me to i can break your truck for free!
